Veho PRO HANDLEBAR MOUNT FOR MUVI
Quicklinx: 7TS2WS00 Mfr#: VCC-A003-PHM
The Pro handle bar mount allows you to fix your micro DV camcorder to your cycle/motorcycle/rollbars securely and reduce vibrations when recording. Its clamping mechanism and foam insert is designed to reduce vibration as well as securely attach the muvi in almost any position. The adjustable mounting ratchet allows you to angle the muvi in any direction to capture the best footage possible.
Veho Pro handle bar mount support system - handle bar mount
Support system - handle bar mount
Placing / Mounting
Handlebar
Support system
Tripod
Placing / Mounting
Handlebar
Supported Devices
Camcorder
Support Type
Handle bar mount
