The Atom Pro Handlebar Mount is designed for the Muvi Atom and allows you to fix your super micro Atom camcorder to your cycle/motorcycle/rollbars securely and reduce vibrations when recording. It has a universal tripod mount connecter and comes complete with clip/mount for your Muvi.
The Professional Handlebar Mount clamping mechanism and foam insert is designed to reduce vibration as well as securely attach the Muvi in almost any position. The adjustable mounting ratchet allows you to angle the Muvi in any direction to capture the best footage possible.
- Veho Atom Pro Handlebar Mount support system - handle bar mount
- Product Type
- Support system - handle bar mount
- Placing / Mounting
- Handlebar
- Product Type
- Support system
Tripod
- Handlebar
- Supported Devices
- Camcorder
- Support Type
- Handle bar mount
Kit Content
- Kit Content
- (1) x tripod adapter , (1) x camera mounting bracket , (1) x handlebar mount
