V7 Bluetooth Portable Speaker - White
Quicklinx: BC74WS00 Mfr#: SP6000-BT-WHT-18EC
Listen to your favorite songs from your Bluetooth enabled device through the crystal clear V7 Bluetooth wireless speaker. You will enjoy its 33 feet range, and hands-free speakerphone function allowing you to answer phone calls from your Bluetooth enabled mobile phone. The powerful 2.5 W speakers have a built-in passive radiator woofer for deep base. The USB rechargeable built-in battery provides longer uninterrupted sound while you're on the go.
V7 SP6000 - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Continuous Power
5 Watt
Frequency Response
80 - 20000 Hz
Amplifier
Integrated
Bluetooth, NFC
Speaker Details
Speaker - stereo x 2 - 2.5 Watt - 80 - 20000 Hz - active
White
Power Options
USB charging, USB powered
Speaker battery rechargeable - lithium polymer
14 cm x 6.6 cm x 9.3 cm
350 g
Hands-Free Function
Enclosure Colour
White
Speaker System
Speaker Type
Active
Continuous Power
5 Watt
Frequency Response
80 - 20000 Hz
Amplifier
Integrated
Bluetooth 3.0, Near Field Communication (NFC)
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Transmission Range
10 m
Controls
Power on/off, volume, call answer
Speaker System Details
Speaker Details
Speaker - stereo x 2 - 2.5 Watt - 80 - 20000 Hz CFR - active
Driver Details
Speaker: 2 x full-range driver , Speaker: Passive Radiator
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , DC power output (4 pin USB Type A (power only))
Micro-USB cable
Power Source
Options
Rechargeable - lithium polymer
Capacity (Ah)
3600 mAh
Run Time (Up To)
16 hour(s)
14 cm
6.6 cm
9.3 cm
350 g
