Urban Armor Gear Scout Rugged Case for iPad 10.2 (9/8 Gen) - White, Grey
Quicklinx: GP5VWS00 Mfr#: 12191HB14130
Colour: White, Grey
14 In Stock
£22.99 ex VAT
£27.58 inc VAT
The Scout Series Healthcare Case for the iPad 10.2" is designed for healthcare providers who depend on their tablet in hospitals, clinics, and other healthcare environments. Meets Mil-Spec 810G and this case has passed rigorous testing for 1.2-meter (4 feet) drops to help protect your device against accidental drops. With functional & portability components like a 360-degree rotational hand strap, Apple Pencil storage, and a replaceable shoulder strap so you can stay on the go. With a smart design and protection, you can trust the Scout Series provides heavy-duty protection shielding your tablet from the day while you're working. Compatible with iPad 10.2-inch (9th Gen, 2021): A2602, A2603, A2604, A2605 & (8th Gen, 2020) : A2270, A2428, A2429, A2430 & (7th Gen, 2019): A2197, A2200, A2198, A2199. Comes in non-retail packaging.
UAG Rugged Case for iPad 10.2-in (9/8 Gen, 2021/2020) w/HS - Scout White/Grey - back cover for tablet
Back cover for tablet
Screen Size Compatibility
10.2"
18.8 cm x 1.65 cm x 27.7 cm
286 g
Grey, white
Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation)
18.8 cm
1.65 cm
27.7 cm
286 g
Grey, white
Carrying Case
Protective cover
Recommended Use
For tablet
10.2"
Protection
Antimicrobial, drop protection, shock protection
Cover Type
Back cover
Carrying Strap
Removable/adjustable shoulder strap, 360° rotatable hand strap
Additional Compartments
Apple Pencil
Raised edges
MIL-STD 810G 516.6
Max Height of Shock Resistance
1.2 m
Lifetime
Colour: White
Colour: Grey
Brand: Urban Armor Gear
