The USRobotics USB-to-Serial Cable allows you to use a computer's USB portto connect to the serial port of a modem or other RS232 device. This easy to install six foot cable uses no IRQs, so you can use multiple serial devices without IRQ conflicts.
- USRobotics - serial adapter - USB - RS-232
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- Ports
- RS-232
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 115.2 Kbps
- Processor
- No CPU
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 115.2 Kbps
Processor / Memory
- Processor
- No CPU
- 1 x RS-232 - 25 pin D-Sub (DB-25)
- Connections
- USB
- Cables Included
- 1 x USB / serial cable - 1.83 m
- Limited warranty - 2 years
