The StoreJet 25H3P portable hard drive is a powerful storage device that combines superior performance of USB 3.0 and a three-stage shock protection system that meets rigorous U.S. military drop-test standards. The StoreJet 25H3P is an ideal option for speed lovers. Transferring an entire DVD movie takes less than a minute to complete!
Besides incorporating a brilliant purple anti-slip rubber enclosure, the StoreJet 25H3P includes a reinforced hard casing that evenly distributes the force of an impact, and an internal hard drive suspension damper as a last line of defense. It is also equipped with an extremely convenient one touch auto-backup button, which lets you instantly backup and synchronize data with your computer.
- Transcend StoreJet 25H3P - hard drive - 2 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 2 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Shock resistant, One-Click backup button
- Power Source
- Additional USB
- Enclosure Colour
- Brilliant purple
- 80.8 mm x 131.8 mm x 24.5 mm
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Capacity
- 2 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Internal Drive Interface
- Serial ATA
- 80.8 mm
- 131.8 mm
- 24.5 mm
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Compatible Bay
- 2.5"
- Power Source
- Additional USB
- Software Included
- Transcend Elite
- OS Required
- Apple MacOS X 10.4 or later, Linux Kernel 2.6.31 or later, Microsoft Windows Vista / XP / 7 / 8
- Cables Included
- 1 x USB power splitter cable - external
- Enclosure Material
- Silicone
- Plug and Play, MIL-STD 810F, BSMI, FCC
- Enclosure Colour
- Brilliant purple
- Limited warranty - 3 years
- 5 °C
- 55 °C
