Wide Range Detection – Captures motion up to 23 ft.(7m) away and through 120° view.
Motion-Activated Light – Control smart lights based on your movement and schedule.
Energy Saving – Automatically turn on connected smart devices when you come and go.
Instant Alerts & App Notification – Alerts you in Away Mode for anything you want to know.
Battery-Powered – Compact battery-powered design supports over one year of use.
Easy Installation – Mount it by attached 3M adhesive or the build-in magnets.
Tapo Hub Required – Tapo H100 (sold separately).
Hands-free control
No more fumbling in the dark. Your hallway or bedroom lights turn on automatically as you pass by the sensor without having to flip a switch or say a word. -
Motion control an entire room
Create a Smart Action to automate your smart devices and activate them all with motion. Customize your own Smart Actions to group your Tapo products together any way you want. -
Guard your home while you're away
The motion sensor can trigger an alarm to deter intruders if it notices anything amiss when you're not home. Receive a notification on your phone as soon as motion is detected. -
Adjustable sensitivity
The sensor captures motion up to 7 meters away with a 120° field of view. Adjust the sensitivity to 3 different levels to tailor your detection coverage and filter out false triggers. -
Flexible sensor angle
Freely rotate the sensor to the ideal angle and adjust the detection zone to avoid accidental activations by your fur babies.
- Tapo T100 V1 - motion sensor - smart - Wi-Fi
- Product Type
- Motion sensor
- Functions
- Light control, motion detection, alarm control
- Power Source
- Battery
- Connectivity
- Wireless - Wi-Fi
- Frequency Band
- 863 - 865 Mhz, 868 - 868.6 MHz
- 2-year warranty
- 4.23 cm x 3.4 cm x 4.23 cm
- Product Type
- Motion sensor
- Functions
- Power Source
- Battery
- Connectivity Technology
- Wireless
- Frequency Band
- LED indicator, magnet mount, power saving, adjustable detection sensitivity, real-time notifications
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Required
- Hub Compatibility
- Tapo Hub
- Compatible Application
- Tapo app
Motion Sensor
- Detection Range
- 7 m
- Detection Angle
- 120 degree(s)
- Form Factor
- CR2450
- Battery Included
- Required Qty
- 1
- Battery Lifetime
- 2 years
- Included Accessories
- Adhesive strip
- Warranty
- 2-year warranty
- VCCI, FCC, RoHS, NCC, RCM, JRF, UKCA, R-NZ
- 4.23 cm
- 3.4 cm
- 4.23 cm
- 0 °C
- 40 °C
- 10 - 90% RH (non-condensing)
