The M7000 supports the latest generation 4G FDD/TDD-LTE networks, providing convenient carry-on Wi-Fi in most countries and regions. Now you can enjoy lag-free HD video, fast file downloads, and stable video chats regardless of where life takes.
This compact device works seamlessly with an impressive range of wireless gadgets. The M7000 can easily share a 4G/3G connection with up to 10 wireless devices like tablets, laptops, and mobile phones at the same time.
Do more with a faster connection
The M7000 supports the latest generation 4G FDD/TDD-LTE networks, providing convenient carry-on Wi-Fi in most countries and regions. Now you can enjoy lag-free HD video, fast file downloads, and stable video chats regardless of where life takes. -
Share with friends internet access for up to 10 devices simultaneously
This compact device works seamlessly with an impressive range of wireless gadgets. The M7000 can easily share a 4G/3G connection with up to 10 wireless devices like tablets, laptops, and mobile phones at the same time. -
Power through your day with up to 8 hours of sharable 4G
With its powerful 2000mAh battery, the M7000 can provide up to 8 hours of wireless connectivity, making it the perfect companion for travel, business trips, outdoor activities, and more. -
Get your network up and running in seconds
M7000 features a compact and user-friendly design, all you need is to insert a SIM card and press the power button. Your high-speed 4G hotspot will be operational within a half-minute. -
Easy management with the tpMiFi App
With the tpMiFi App, you can easily access and manage the M7000 from your connected iOS/Android devices. The tpMiFi app allows you to establish data limits, control which devices can access your Wi-Fi and send messages.
- TP-Link M7000 - mobile hotspot - 4G LTE
- Mobile hotspot
- Form Factor
- External
- Max Transfer Rate
- 150 Mbps
- Mobile Communication Protocol
- UMTS, HSPA, HSPA+, FDD LTE, TDD LTE
- Mobile Band
- LTE B1/B20/B3/B5/B7/B8
- Networking
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n - 300 Mbps
- Battery
- 2000 mAh - up to 8 hrs
- System Requirements
- Android, Apple iOS
- 9.4 cm x 5.67 cm x 1.98 cm
- Mobile hotspot
- Form Factor
- External
- Built-in Devices
- LED display
Modem
- Connectivity Technology
- Wireless
- Max Transfer Rate
- 150 Mbps
- Mobile Band
- Antenna
- Internal
- Wireless
- Data Link Protocol
- Data Transfer Rate
- 300 Mbps
- MAC address filtering, DHCP server, reset button, DHCP client
- 1 x micro-USB
- SIM Card Supported
- Regular (mini-SIM) x 1
- Cables Included
- 1 x micro-USB cable
- Encryption Algorithm
- WPA-PSK, WPA2-PSK
- RoHS
- Capacity
- OS Required
- 9.4 cm
- 5.67 cm
- 1.98 cm
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
FZ69 048649 Condition: Customer return - item has been opened but is in excellent condition |
£32.26 | |||||
Ref:
FZ69 048650 Condition: has been opened in excellent condition |
£32.26 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
