TP LINK M7000 150Mbps 4G LTE Mobile Wi-Fi
Quicklinx: FZ69WS00 Mfr#: M7000
Type: Mobile hotspot
Enclosure: External
Interface: [N/A]
Compatibility: [N/A]
33 In Stock
£36.21 ex VAT
£43.45 inc VAT
The M7000 supports the latest generation 4G FDD/TDD-LTE networks, providing convenient carry-on Wi-Fi in most countries and regions. Now you can enjoy lag-free HD video, fast file downloads, and stable video chats regardless of where life takes.
This compact device works seamlessly with an impressive range of wireless gadgets. The M7000 can easily share a 4G/3G connection with up to 10 wireless devices like tablets, laptops, and mobile phones at the same time.
  • Do more with a faster connection
  • Share with friends internet access for up to 10 devices simultaneously
  • Power through your day with up to 8 hours of sharable 4G
    With its powerful 2000mAh battery, the M7000 can provide up to 8 hours of wireless connectivity, making it the perfect companion for travel, business trips, outdoor activities, and more.
  • Get your network up and running in seconds
    M7000 features a compact and user-friendly design, all you need is to insert a SIM card and press the power button. Your high-speed 4G hotspot will be operational within a half-minute.
  • Easy management with the tpMiFi App
    With the tpMiFi App, you can easily access and manage the M7000 from your connected iOS/Android devices. The tpMiFi app allows you to establish data limits, control which devices can access your Wi-Fi and send messages.
TP-Link M7000 - mobile hotspot - 4G LTE
Mobile hotspot
External
Max Transfer Rate
150 Mbps
Mobile Communication Protocol
UMTS, HSPA, HSPA+, FDD LTE, TDD LTE
Mobile Band
LTE B1/B20/B3/B5/B7/B8
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n - 300 Mbps
2000 mAh - up to 8 hrs
Android, Apple iOS
9.4 cm x 5.67 cm x 1.98 cm
Mobile hotspot
External
Built-in Devices
LED display
Modem
Wireless
Max Transfer Rate
150 Mbps
Mobile Band
Antenna
Internal
Wireless
Data Transfer Rate
300 Mbps
MAC address filtering, DHCP server, reset button, DHCP client
1 x micro-USB
SIM Card Supported
Regular (mini-SIM) x 1
1 x micro-USB cable
Encryption Algorithm
WPA-PSK, WPA2-PSK
RoHS
Android, Apple iOS
9.4 cm
5.67 cm
1.98 cm
35 °C
10 - 90% (non-condensing)
Enclosure: External
Interface: [N/A]
Brand: TP LINK
