TP LINK KP303 Kasa Smart WiFi Power Strip - 3 Outlets, 2 USB Ports
Quicklinx: FMM8WS00 Mfr#: KP303
Type: Smart plug
Compatible With: Alexa, Google Assistant
15 In Stock
£23.33 ex VAT
£27.99 inc VAT
Smart Controls with Surge Protection in One
Kasa Smart Wi-Fi Power Strip
Individually Control 3 Smart Outlets
With 3 smart outlets that can be separately managed and 2 always-on USB ports, the Kasa Smart Wi-Fi Power Strip meets your diverse needs like supporting multiple appliances from lamps to humidifiers and more simultaneously or independently.
Control from Anywhere
Control up to 3 devices individually or collectively with the Kasa Smart app. Remotely turn off/on plugged-in devices such as lamps, fans, heaters and other devices.
Voice Control
Compatible with Alexa and Google Assistant. Free up your hands by using voice commands to control plugged in devices.
Set Schedules and Timers
Create schedules/timers to turn outlets on/off at specific times to improve convenience and efficiency, manage complicated set-ups like high-end fish tanks, and cut down on power consumption.
Space Saving Design
The right-angled flat plug is designed to leave other outlets free and easily fit behind furniture and in tight spaces.
Surge Protection
Surge protection shields sensitive electronics and appliances from sudden electrical surges and spikes, including those caused by lightning or short circuits. Keep your devices safe during thunderstorms.
No Hub Required
Connect to any secured 2.4 GHz wireless network to control directly. No need for a separate hub or extra equipment.
Your Home. One App.
Turn your home into a true smart home with Kasa Smart. Automate your lights and appliances with smart plugs and bulbs. Secure your home with Kasa Cameras. Control it all from the Kasa Smart app.
  • 3 smart outlets + 2 USB ports
    Supports 5 appliances simultaneously with 3 independently controllable smart outlets and 2 always-on USB ports. Ideal for charging devices in the home and office.
  • Surge protection
    Surge protection shields sensitive electronics and appliances from sudden power surges that can occur during thunderstorms.
  • Control from anywhere
    The Kasa Smart Wi-Fi power strip plus free Kasa Smart app allows you to remotely control connected devices through your mobile devices.
  • Voice control
  • Set schedules & timers
    Create schedules/timers to turn outlets on or off at specific times to improve convenience and efficiency, and cut down on power consumption.
TP-Link Kasa KP303 - smart power strip
Smart power strip - external
470 g
Input Connectors
1 x power 3-pole
Output connectors
3 x power (surge) , 2 x 4 pin USB Type A - 5 V 2.4 A
Intelligent Assistant
Google Assistant, Alexa
IEEE 802.11 b/g/n
Android 5.0 or later, Apple iOS 10 or later
26 cm x 6.34 cm x 3.86 cm
Input Connectors
1 x power 3-pole
Surge Suppression
Remote Management Interface
IEEE 802.11 b/g/n
Internet of Things (IoT)
Communications Technology
Wi-Fi
Power cable - integrated
Surge protection, for indoor use, Voice Control, over current protection, built-in 2-port USB charger, switched per outlet
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
10 - 90% (non-condensing)
26 cm
6.34 cm
3.86 cm
470 g
Shipping Width
34 cm
Shipping Depth
9.5 cm
Shipping Height
4.8 cm
Type: Smart plug
Brand: TP LINK
