TP LINK AV1000 Gigabit Passthrough Powerline Starter Kit
Quicklinx: FZ66WS00 Mfr#: TL-PA7017PKIT
Type: Powerline adapter kit
Speed: 1Gbps
Connectivity: Wired
Pass-through Socket: Yes
£41.19 ex VAT
£49.42 inc VAT
Coming with advanced HomePlug AV2 technology, TL-PA7017P KIT provides users with high-speed data transfer rates of up to 1000 Mbps - ideal for bandwidth-intensive applications such as multiple HD/3D/4K video streaming, online gaming, and large file transfers. With one Gigabit Ethernet port, TL-PA7017P KIT allows users to connect a bandwidth-intensive device to the internet at high speeds, ensuring smooth streaming for Ultra HD videos. This makes the TL-PA7017P KIT the perfect home entertainment companion.
  • 1000 Mbps perfect for bandwidth-hungry activities
  • Gigabit port for ultra-fast data transfer
  • Plug and Play, no configuration required
    Connect a powerline adapter to the router. Plug another powerline adapter into a wall socket in another room. Connect it to your internet enabled device via Ethernet - and you're done!
  • Extra power outlet for additional devices
    Finding it hard to plug in your devices? The TL-PA7017P KIT has an integrated AC pass-through power socket. Your powerline adapter can now be used like a traditional electrical outlet. Plug your smart TV or game consoles into the adapter. No socket left to waste. The built-in noise filter helps prevent electrical signal noise from affecting your powerline performance.
  • Up to 85% power saved
    The future's looking green for powerline adapters. TL-PA7017P KIT's practical design and sophisticated Power-Saving Mode, which automatically switches from its regular "Working" mode to "Power-Saving" mode, reduces its energy consumption by up to 85%.
TP-Link AV1000 - Gigabit Passthrough Starter Kit - powerline adapter kit - wall-pluggable
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0, IEEE 1901
Data Transfer Rate
1 Gbps
Reset button
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0
AC 220 V (50 Hz)
5.8 cm x 4.2 cm x 9.5 cm
Apple MacOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 2000/XP/Vista/7, Windows 8, Windows 8.1
Packaged Quantity
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
1 Gbps
Encryption Algorithm
128-bit AES
Reset button
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0, RoHS
Status Indicators
Power, LAN, powerline
Line Properties
Line Coding Format
OFDM
LAN: 1 x HomePlug AV 2.0
AC 220 V (50 Hz)
2.3 Watt
1 x network cable
5.8 cm
4.2 cm
9.5 cm
10 - 90% (non-condensing)
Speed: 1Gbps
Connectivity: Wired
Brand: TP LINK
