TP LINK 150Mbps Wireless N PCI Adapter
Quicklinx: 7NCRWS00 Mfr#: TL-WN751ND
  • IEEE 802.11n
TP-LINK TL-WN751ND is designed to provide a complete end-to-end wireless performance from the server or server backbone to the switch infrastructure and down through to the desktop with the PCI connector. TL-WN751ND Wireless N PCI Adapter provides a wider compatibility, fitting with any standard 32-bit PCI slot. Compared with standard PCI network cards, it offers increased bandwidth, reliability and more functionality, allowing you to enjoy a fast and advanced connection, such as downloading, making internet call and video streaming.
Complying with the IEEE 802.11n standard, TL-WN751ND can easily establish a wireless network and get up to 9X the speed and 4X the range of conventional 11g products. Compared with legacy 54M products, TL-WN751ND delivers performance enhancements, allowing you to have a more joyful surfing experience, including sharing files, watching streaming media.
As for the security of WI-FI connection, WEP encryption has been no longer the strongest and safest guards for outside intrusions. TL-WN751ND provides WPA/WPA2 encryptions that are created by the WI-FI Alliance industry group, preventing the wireless network from outside threats.
Compatible with WI-FI Protected Setup (WPS), TL-WN751ND features Quick Security Setup (QSS) function, which is ideal for creating a WPA encrypted connection to prevent outside intrusion, and meanwhile maximize the management resources. Not only is this faster than normal security setups but more convenient in that you don't need to remember a password!
TL-WN751ND offers external antenna that can be rotated and adjusted in different directions to fit various operation environments, and can bring better performance than the internal antenna. For even more demanding applications, the antenna can be replaced with diverse antennas to show even greater flexibility and wider wireless coverage.
Header / Manufacturer
TP-LINK Technologies
Header / Model
TL-WN751ND 150Mbps Wireless N PCI Express Adapter
PCI
Plug-in card
Network adapter
Wired / Wireless
Wireless
Header / Product Line
TP-Link
Compatibility
PC
System Requirements / OS Required
Microsoft Windows 2000/XP/Vista/7
Protocol
IEEE 802.11n
Miscellaneous / Encryption Algorithm
WPA2-PSK
Dimensions & Weight / Width
2.2 cm
Speed
150 Mbps
Dimensions & Weight / Depth
13.3 cm
Dimensions & Weight / Height
12.1 cm
Header / Packaged Quantity
1
