Toshiba Slim Port Replicator 3
Quicklinx: 6BGLWS00 Mfr#: PA3681E-2PRP
The Slim Port Replicator III provides fast desktop environment access for your Portege and eliminates the hassle of connecting multiple cables time after time. Simply place your laptop in the guide lugs and snap it into place to connect to your monitor, network cable and all your essential USB PC accessories - it even charges the battery while you work. The two special 'wake-up' features turn on your computer when it receives a wake-up signal from either LAN cable, or from a device connected to a USB port.
Toshiba Slim Port Replicator III - port replicator
Port replicator
Power adapter - external Power Provided
Dynabook Toshiba Portégé A600, A600 3G-12, R500, R500 3G-11, R500 3G-121, R600, R600 -014
Port replicator
1 x docking / port replicator - 64 pin docking , 1 x network - 10Base-T/100Base-TX - RJ-45 , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 6 x USB 2.0 - 4 pin USB Type A , 1 x audio - line-out/line-in , 1 x microphone - input - mini-phone 3.5 mm , 1 x headphones - output - mini-phone stereo 3.5 mm
Dynabook Toshiba Portégé A600, A600 3G-12T, A600-01K, A600-122, A600-126, A600-128, A600-12B, A600-12C, A600-12H, A600-12M, A600-12O, A600-12T, A600-12X, A600-12Y, A600-133, A600-13S, A600-13T, A600-13X, A600-13Y, A600-13Z, A600-142, A600-14C, A600-14R, A600-152, A600-161, A600-EC1, A600-S2201, A600-SP2801R, A600-ST2230, A600-ST2231, A600-ST2232, R500, R500 3G-11N, R500 3G-121, R500-00V, R500-02G, R500-100, R500-106, R500-10I, R500-10J, R500-10K, R500-10L, R500-10N, R500-10U, R500-110, R500-11B, R500-11C, R500-11F, R500-11H, R500-11I, R500-11J, R500-11K, R500-11L, R500-11N, R500-11T, R500-11X, R500-11Y, R500-11Z, R500-120, R500-121, R500-124, R500-125, R500-126, R500-127, R500-12B, R500-12H, R500-12I, R500-12J, R500-12P, R500-12Q, R500-12R, R500-12s, R500-133, R500-135, R500-136, R500-3G11K, R500-3G125, R500-S5001X, R500-S5002, R500-S5002X, R500-S5003, R500-S5004, R500-S5006V, R500-S5006X, R500-S5007V, R500-S5008x, R500-SP1, R500-SP2, R500-SSD, R600, R600 -014, R600-101, R600-102, R600-108, R600-10F, R600-10M, R600-10Q, R600-10S, R600-10T, R600-10W, R600-10X, R600-119, R600-11A, R600-11Q, R600-S4201, R600-S4202, R600-SP2801C, R600-SP2801R, R600-ST520W, R600-VH3
