Toshiba Main Battery Pack 10.8v 6100mA
Quicklinx: 7CT3WS00 Mfr#: PA3832U-1BRS
The Toshiba Primary Battery Pack is a rechargeable, Lithium Ion battery. Used as either a spare or replacement battery, this battery pack meets or exceeds the specifications of the original battery that came with your notebook. It interfaces with the Toshiba Power Saver Utility on the notebook which features a charge indicator to help you monitor the available power.
Toshiba Primary Battery Pack - laptop battery - Li-Ion - 6200 mAh
Laptop battery
317.5 g
Lithium Ion 6-cell - 6200 mAh
20.8 cm x 4.3 cm x 2 cm
1-year warranty
Dynabook Toshiba Portégé R700, R700 3G/EX-1DZ, R700 EX-11, R700 EX-123, R705, R830, R930; Toshiba Tecra R700, R840, R940; Satellite R630, R830, R930
Laptop battery
6-cell Lithium Ion
Voltage Provided
10.8 V
6200 mAh
RoHS
Limited warranty - 1 year
20.8 cm
4.3 cm
2 cm
317.5 g
Dynabook Toshiba Portégé R700 3G/EX-1DZ, R700 EX-11G, R700 EX-123, R700-01B, R700-02B, R700-100, R700-110, R700-12D, R700-12K, R700-12R, R700-135, R700-136, R700-14F, R700-14L, R700-14M, R700-14N, R700-153, R700-157, R700-158, R700-15C, R700-15E, R700-15H, R700-15J, R700-15L, R700-15V, R700-15Z, R700-16R, R700-173, R700-174, R700-177, R700-179, R700-17G, R700-17H, R700-17N, R700-17W, R700-17X, R700-17Z, R700-181, R700-182, R700-183, R700-184, R700-185, R700-187, R700-18C, R700-18G, R700-18P, R700-18Q, R700-19F, R700-19L, R700-19M, R700-19T, R700-1C2, R700-1C4, R700-1CC, R700-1CF, R700-1CQ, R700-1CX, R700-1CZ, R700-1D1, R700-1D3, R700-1DC, R700-1DD, R700-1DE, R700-1DF, R700-1DG, R700-1DH, R700-1DJ, R700-1DL, R700-1DM, R700-1DN, R700-1DP, R700-1DT, R700-1E0, R700-1E1, R700-1EG, R700-1EH, R700-1EL, R700-1EZ, R700-1F0, R700-1F1, R700-1F2, R700-1F3, R700-1F4, R700-1F5, R700-1F6, R700-1F7, R700-1FK, R700-1FL, R700-1FN, R700-1FP, R700-1G0, R700-1G4, R700-K01, R700-K02, R700-K03, R700-K05, R700-S1312, R700-S1322, R700-S1322W, R700-S1332, R700-S1332W, R700-ST1303, R700-W1322, R830-0F5, R830-0F6, R830-0H4, R830-0KF, R830-1G2, R930-109, R930-10J, R930-115, R930-116, R930-117, R930-12Q, R930-13U, R930-14T, R930-14X, R930-14Z, R930-151, R930-152, R930-153, R930-18L, R930-1CW, R930-1CX, R930-1CZ, R930-1D0, R930-1D7, R930-1FU, R930-1FV , Dynabook Toshiba Tecra R840-17Q, R840-17R, R840-198, R940-1CV, R940-1CW, R940-1D6, R940-1DC, R940-1EE, R940-1FD, R940-1FE, R940-1FF, R940-1FH, R940-1FT, R940-1GQ, R940-1GT, R940-1JF, R940-1JG, R940-1JH, R940-1KF, R940-1KR, R940-1L0, R940-1L1, R940-1MJ , Toshiba Satellite R630-102, R630-105, R630-130, R630-131, R630-139, R630-13K, R630-13N, R630-13P, R630-13R, R630-13T, R630-13U, R630-13V, R630-13Z, R630-140, R630-141, R630-144, R630-145, R630-146, R630-148, R630-149, R630-14H, R630-14J, R630-14R, R630-14T, R630-14X, R630-153, R630-155, R630-156, R830-1G0, R830-1GZ, R830-1L7, R930-16W, R930-1CV
