Toshiba Hi Speed Port Replicator II
Quicklinx: 7WNSWS00 Mfr#: PA3916B-1PRP
The Hi-Speed Port Replicator II provides fast desktop environment access for your Portégé R700 or R830, Tecra R840, or Tecra R850 laptop and eliminates the hassle of connecting multiple cables time after time. Simply place your laptop in the guide lugs and snap it into place to connect to your monitor, network cable and all your essential USB PC accessories - it even charges the battery while you work.
The Hi-Speed Port Replicator II enhanced technical features include
  • 1 x VGA port,
  • 1 x Serial Port,
  • 4 x USB 2.0 ports (downstream),
  • 2 x USB 3.0 ports (downstream),
  • 1 x 1Gbps Ethernet LAN connection,
  • 1 x HDMI, 1 x Display Port (Shuttered),
  • Audio line in/out, 1 x Microphone in,
  • AC Adaptor (19V/90W),
  • 1 x UK power cord.
Other features include a 100 pin docking connector, Power Button, Undock Button, PC lock switch and Kensington lock slot.
  • No more cables
    Just dock your laptop and start working. The easiest way to get connected to all your desktop peripherals and charge your laptop at the same time.
  • Your working environment
    Local and network printers, external storage, second screen, keyboard and mouse - your working area, just how you like it. With the Hi-Speed port replicator you have everything at hand, just by connecting your Toshiba laptop.
  • Various interfaces in an instant
    With the USB interfaces of the Hi-Speed port replicator you can connect up to 6 USB devices to your laptop at once. Two of them even with USB 3.0. Choose between the HDMI port or a display interface for easy operation directly.
Toshiba Hi Speed Port Replicator II (2-pin) - port replicator
Port replicator
37.9 cm x 16.9 cm x 3.2 cm
0.95 kg
United Kingdom
Power adapter - external 90 Watt Power Provided
Dynabook Toshiba Portégé R700, R700 3G/EX-1DZ, R700 EX-11, R700 EX-123, R830, R830 3G/SSD-13, R830 3G-14, R930; Toshiba Tecra R840, R850, R940, R950
Port replicator
37.9 cm
16.9 cm
3.2 cm
0.95 kg
United Kingdom
2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 4 x USB 2.0 - 4 pin USB Type A , 1 x serial , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x microphone - input - mini-phone 3.5 mm , 1 x audio - output - mini-phone stereo 3.5 mm , 1 x display / video - DisplayPort - 20 pin DisplayPort
1 x HDMI cable - external
Security Slot Type
Kensington security slot
VCCI, IC, FCC
Power Provided
90 Watt
Dynabook Toshiba Portégé R700-12R, R830-003, R830-030, R830-031, R830-05L, R830-06R, R830-08S, R830-0F5, R830-0F6, R830-0GE, R830-0H4, R830-0KF, R830-104, R830-11Q, R830-130, R830-157, R830-17C, R830-17P, R830-17U, R830-180, R830-192, R830-194, R830-19R, R830-1C8, R830-1DR, R830-1DT, R830-1DU, R830-1ED, R830-1EE, R830-1EQ, R830-1FR, R830-1G2, R830-1GC, R830-1GD, R830-1H5, R830-1HD, R830-1JK, R830-1JM, R830-1JN, R830-1JP, R830-1JQ, R830-1JV, R830-1JX, R830-1JZ, R830-1K1, R830-S8312, R830-S8322, R830-S8332, R830-SP3137L, R930-109, R930-10J, R930-115, R930-116, R930-117, R930-12Q, R930-13U, R930-14T, R930-14X, R930-14Z, R930-151, R930-152, R930-153, R930-18L, R930-1CW, R930-1CX, R930-1CZ, R930-1D0, R930-1D7, R930-1FU, R930-1FV , Dynabook Toshiba Tecra R840-04H, R840-10R, R840-12Z, R840-14H, R840-14P, R840-14Q, R840-14R, R840-14T, R840-14X, R840-15J, R840-160, R840-16J, R840-16L, R840-16Q, R840-16W, R840-17Q, R840-17R, R840-18T, R840-18W, R840-18Z, R840-195, R840-198, R840-199, R840-19P, R840-S8412, R840-S8413, R840-S8419, R840-S8422, R840-S8432, R850-00U, R850-05E, R850-05F, R850-06P, R850-08W, R850-11N, R850-14C, R850-17L, R850-18E, R850-18F, R850-18H, R850-18J, R850-18L, R850-19J, R850-1C0, R850-1C1, R850-1CD, R850-1CF, R850-1CH, R850-1CL, R850-1CN, R850-1CX, R850-1D7, R850-1D8, R850-1DC, R850-1DD, R850-1EN, R850-1EP, R850-1F8, R850-1GK, R850-1GV, R850-1H7, R850-1HD, R850-1HG, R850-1HP, R850-1HU, R850-1HV, R850-1HX, R850-1J2, R850-1J5, R850-1JC, R850-1JD, R850-S8512, R850-S8513, R850-S8519, R850-S8522, R850-S8529, R850-S8532, R850-S8552, R850-SP5161M, R940-1CV, R940-1CW, R940-1D6, R940-1DC, R940-1EE, R940-1FD, R940-1FE, R940-1FF, R940-1FH, R940-1FT, R940-1GQ, R940-1GT, R940-1HV, R940-1JF, R940-1JG, R940-1JH, R940-1KF, R940-1KR, R940-1L0, R940-1L1, R940-1MJ, R950-106, R950-11E, R950-11F, R950-12Q, R950-153, R950-155, R950-176, R950-18K, R950-1CL, R950-1EJ, R950-1EK, R950-1EL, R950-1EM, R950-1EN, R950-1JH, R950-1JJ
