SUPER SPEED STORAGE MADE SIMPLE
Quickly transfer files with SuperSpeed USB 3.0 and store up to 2 TB of data on STOR.E BASICS external drives. Easy to use and backward compatible with USB 2.0, STOR.E BASICS external drives are ready to use with Microsoft Windows with no software installation required.
CAPACITY: 750GB
INTERFACE: USB 3.0 (USB 2.0 compatible)
INTERFACE TRANSFER RATE: Max. 5.0 Gbps
ON-BUS POWER: Max. 900 mA
DIMENSION: 118.9 mm (L) x 79 mm (W) x 13.5 mm (H)
WEIGHT: approx. 150 g
COLOUR: Matt black
System requirements
Microsoft® Windows® XP / Vista /Windows® 7 / Windows 8 / Windows 8.1
CPU with 750 MHz or faster
10MB system hard disk space
256MB system memory
one free port of USB 3.0 or USB 2.0
Box contents
STOR.E BASICS
USB 3.0 cable ("A" to Micro "B")
Quick Start Guide
Warranty Leaflet
pre-installed Users Manual
- Toshiba StorE BASICS - hard drive - 750 GB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 750 GB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Silent HDD, Ramp Load
- Power Source
- USB bus
- Enclosure Colour
- Matte black
- 7.9 cm x 11.9 cm x 1.4 cm
- 150 g
- Designed For
- Qosmio X870-13Z, X870-140, X870-141, X870-142, X870-15K
- Capacity
- 750 GB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- 7.9 cm
- 11.9 cm
- 1.4 cm
- 150 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Compatible Bay
- 2.5"
- Power Source
- USB bus
- OS Required
- Microsoft Windows 7
- Cables Included
- 1 x USB 3.0 cable - external
- Plug and Play
- Enclosure Colour
- Matte black
- Designed For
- Toshiba Qosmio X870-13Z, X870-140, X870-141, X870-142, X870-15K
