Store data securely on the new Canvio Connect external hard drive. It's quick and easy to transfer your files via SuperSpeed USB 3.0, and you can also organize data and backup files with pre-loaded NTI® Backup Now EZ™ software. You can even access your data remotely and wirelessly from another PC, tablet or smartphone! Additionally you have 10GB free cloud storage.
Secure Data with Built-in Freedom
With the new STOR.E CANVIO external hard drive, you get the best of everything - the satisfaction of storing your data securely and the freedom to access it on the move.
With 10GB Cloud Storage and Remote Access Software
Store up to 10GB of data securely in the cloud and access it whenever you want, on your PC, smartphone or tablet. And with remote access software for your mobile devices, the data on your STOR.E CANVIO is always within easy reach too. Even when you're on the go.
Super Speed Storage USB 3.0
Powered by new USB 3.0 technology, these hard drives are far faster than--but still compatible with--USB 2.0 technology. That's important for speedy transfer when organising your files.
Auto-Backup Software Onboard
The pre-loaded NTI® Backup Now EZ™ software comfortably and reliably provides file, folder, and full system backup and recovery.
NTFS Driver for Mac Included
The on-board NTFS for Mac driver allows you to use the STOR.E CANVIO on both Windows PC and Apple Macintosh platforms.
With remote access software you can access all your files on your STOR.E CANVIO from your mobile devices anywhere.* STOR.E CANVIO must be connected to a PC and WiFi environment. (PC must be on or in stand-by mode)
Specification
- Interface USB 3.0 (USB 2.0 Compatible)
- Max Transfer Rate 5.0GBs
- Enclosure Glossy piano finish
- Colour Black
- Capacity 500GB
- File System NTFS (MS Windows) The drive can be re-formatted to HFS+ file system for full Mac Compatibility
- Power USB bus power (max. 900mA)
- Dimensions 111mm x 79mm x 15mm
- Weight 165g
- Backup Software NTI Backup Now EZ
- Mac NTFS Compatibility Driver Tuxera NTFS for Mac
- Remote Access Software Pogoplug PC
- Others 10GB Cloud Storage (Pogoplug)
- System Requirements Windws XP ? Windows 7 / Windows 8, Apple Mac OS X 10.6.6 or above
- CPU with 750 MHz or faster, 10MB system hard disk space, 256MB system memory, one free port of USB 3.0 or USB 2.0
Box Contents
- Stor.E Canvio
- NTI Backup Now EZ software (pre-loaded)
- Tuxera NTFS for Mac driver software (pre-loaded)
- Pogoplug PC for Toshiba (pre-loaded)
- USB 3.0 micro-B cable
- Quick Start Guide User's Manual (pre-installed on the hard drive)
- Warranty Leaflet
Portable peace of mind
With Toshiba's Canvio 3.0 portable hard drive you get a complete backup solution without the worries. It is home sweet home for all your documents, music, pictures or videos and a great way to share. -
Extra hard drive protection
Offering a built-in internal shock sensor and ramp-loading technology, Canvio 3.0 portable hard drives help safeguard your data against accidents, drops and other unfortunate real-life scenarios. -
A stylish design
Canvio 3.0 portable hard drive is easy to carry, stay where you put them, and make quite a fashion statement. -
Faster transfer speeds
Featuring USB 3.0 technology, Canvio 3.0 portable hard drive is far faster than - but still compatible with - USB 2.0 technology. -
Cloud backup capabilities
Put your backups on the cloud and your concerns on hold. The Canvio 3.0 portable hard drive comes with integrated cloud backup capabilities.
- Toshiba StorE Canvio - hard drive - 500 GB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 500 GB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Power Source
- USB bus
- Enclosure Colour
- Black
- 79 mm x 111 mm x 15 mm
- 165 g
- Capacity
- 500 GB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- 79 mm
- 111 mm
- 15 mm
- 165 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Compatible Bay
- 2.5"
- Power Source
- USB bus
- Software Included
- Drivers & Utilities, NTI Backup NOW! EZ
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Windows 8, Apple MacOS X 10.6.6 or later
- System Requirements Details
- 750 MHz - RAM 256 MB
- Cables Included
- 1 x USB 3.0 cable - USB Type A to micro-B - external
- Enclosure Colour
- Black
