Toshiba 500GB Canvio Connect II USB 3.0 2.5" Portable HD Blue
Quicklinx: B3Y7WS00 Mfr#: HDTC805EL3AA
The Canvio Connect II is a smart storage solution that will soon become your favourite data companion. Not only do you get up to 3 TB of portable storage, backing up your files also is a breeze, thanks to the pre-installed NTI® Backup Now EZ™ software. A NTFS driver for Mac is also included, so you can use the Canvio Connect II on both Windows PC and Apple Macintosh platforms. And all this is packed into a solid, stylish enclosure available in five colours that fit in the palm of your hand.
More terabytes, more colours
The go-anywhere Canvio Connect II puts up to 3 TB of external storage into the palm of your hand. The sleek, sturdy chassis comes in a variety of colours to match your style. It will soon become your favourite data companion.
SuperSpeed USB 3.0
Powered by USB 3.0 technology, these hard drives are far faster than—but still compatible with—USB 2.0 technology. That's important for speedy transfer when organising your files.
Complete backup soloution
The pre-loaded NTI® Backup Now EZ™ software provides comfortable and reliable file, folder, and full system backup and recovery.
Safeguard your data
Since life on the road can be rough and tumble, the Canvio Connect II has taken extra precautions to safeguard your data from shock. It includes an internal shock sensor and ramp loading technology to help keep your drive safe on the go.
Mac and PC
Because a NTFS driver for Mac is included, there are no worries with compatibility. Whether it's a PC or a Mac - or both - just plug in your Canvio Connect II and get instant access to your files.
Toshiba Canvio Connect II - hard drive - 500 GB - USB 3.0
Hard drive - external (portable)
500 GB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Bus Powered by USB, NTFS formatted
Power Source
USB bus
Enclosure Colour
Blue
7.8 cm x 10.9 cm x 1.4 cm
165 g
Bundled with
10GB free Cloud Backup
500 GB
2.5"
USB 3.0
7.8 cm
10.9 cm
1.4 cm
165 g
Bundled with
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Compatible Bay
2.5"
Power Source
USB bus
Software Included
NTI Backup NOW! EZ, Pogoplug PC, Tuxera NTFS Driver for Mac
Apple MacOS X 10.6.6 or later, Microsoft Windows 7 / 8 / 8.1
System Requirements Details
750 MHz - RAM 256 MB
1 x USB 3.0 cable - USB Type A to micro-B - external
Enclosure Colour
Blue
