Quickly transfer files with SuperSpeed USB 3.0 and store up to 1 TB of data on STOR.E PLUS external drives. Easy to use and backward compatible with USB 2.0, STOR.E PLUS external drives are ready to use with Microsoft Windows with no software installation required.
- Toshiba StorE PLUS - hard drive - 2 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 2 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- NTFS formatted
- Enclosure Colour
- Black
- 77 mm x 117 mm x 20.6 mm
- 234 g
- Capacity
- 2 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- NTFS formatted
- 77 mm
- 117 mm
- 20.6 mm
- 234 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Compatible Bay
- 2.5"
- OS Required
- Microsoft Windows Vista / XP / 7 / 8
- System Requirements Details
- Windows XP/Vista/7/8 - 750 MHz - RAM 256 MB
- Cables Included
- 1 x USB 3.0 cable - external
- Enclosure Colour
- Black
