If you're looking for a case that will keep your iPhone protected then look no further. The rugged pro protective case from techair encases your phone with impact protection technology, additional corner bumpers add further protection. techair has even included a clip-on holster. Now that's function with emotion!
- techair classic pro - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 7.99 cm x 3 cm x 15 cm
- 117 g
- Material
- Polycarbonate, thermoplastic polyurethane (TPU)
- Black
- Limited lifetime warranty
- Designed For
- Apple iPhone 6, 6s, 7, 8, SE (2nd generation)
- 7.99 cm
- 3 cm
- 15 cm
- 117 g
- Rugged
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
- Included Accessories
- Belt clip holster
- Lifetime
- Designed For
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
GJD7 048541 Condition: Customer return - item has been opened but is in excellent condition |
£4.50 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
