Synology RS2212+ 10 Bay NAS Enclosure
Quicklinx: 8FN5WS00 Mfr#: RS2212+
Synology RackStation RS2212+ offers a high-performance, scalable, and full-featured network attached storage solution that meets the needs of business that requires an efficient way to centralize data protection, simplify data management, and rapidly scale storage capacity with minimal time spent on setup and management.
Businesses need a strong foundation to face mission-critical tasks. Synology RS2212+ delivers high data availability to ensure access when it's needed. The 2 LAN with failover support and hot-swappable drives will ensure continual service uptime should the drives need replacement or the unexpected LAN failure. CPU is the heart of any system, and RS2212+ incorporates a passive cooling structure to avoid the dependency of a dedicated processor cooling fan, and mitigate any critical point of failure. When system detects fan fails, the built-in redundancy mechanism will spin up the functional fan to properly ventilate the system, and support continuous operations until the replacement fan arrives. Therefore, potential system damages are minimized and system availability is maximized.
  • Experience high performance data throughput
    With the link aggregation enabled, Synology RS2212+ delivers an average 202.26 MB/sec reading speed under RAID 5 configuration in a Windows environment, and 194.37 MB/sec writing. Synology RS2212+ brings you the high performance that your data-intensive applications demand for a storage system, and offer the ability to scale the storage capacity.
  • High reliability for critical business applications
  • Fit to business environment
    Windows ADS integration allows the Synology RS2212+ to quickly and easily fit in an existing business network environment with no need to recreate users' accounts on the Synology RS2212+. The user home feature minimizes the administrator's effort in creating a private shared folder for a large amount of users. Windows ACL support on RS2212+ provides much finer-grained access control and efficient privilege settings, allowing IT staffs to set up privileges to files and folders on RS2212+ through familiar Windows user interface.
  • iSCSI and virtualization ready
    With the iSCSI support in DSM, the Synology RS2212+ provides a seamless storage solution for virtualization servers, such as VMware, Hyper-V, and Citrix. It is the ideal alternative to SAN solution for businesses. Affordable and cost-effective, iSCSI allows SMB users to consolidate storage into data center storage arrays while providing hosts with the illusion of locally-attached disks.
  • Full-featured business applications
    The Synology RS2212+ runs on the renowned operating system, Synology DSM, offering comprehensive applications and features designed specifically for SMBs. Internet file access is simplified by the encrypted FTP server and the web-based file explorer, Synology file station. HTTPS, firewall, and IP auto-block support ensure file sharing over the Internet is protected at a high security level.
  • Energy efficient design
    Synology RS2212+ is designed and developed with energy efficiency in mind. RS2212+ consumes a relatively low amount of power. The support of wake on LAN/WAN and scheduled power on and off can further reduce power consumption and operation cost. HDD hibernation can be configured to take effect automatically when the system has been inactive for a specified period of time. This not only saves energy but also extends the lifespan of the hard disks.
Synology RackStation RS2212+ - NAS server - TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Max Supported Capacity
40 TB
0 (installed) / 10 (max)
44.5 cm x 57 cm x 8.8 cm
12.2 kg ()
1 x 2.13 GHz (Dual-Core)
Storage Controller
RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
RAM
1 GB
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
TAA Compliant
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
40 TB
44.5 cm
57 cm
8.8 cm
12.2 kg ()
Processor / Memory
Processors Installed
1 x 2.13 GHz
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
1 GB (installed) / 3 GB (supported) - DDR3
Storage Controller
RAID - internal
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
HDD - hot-swap - 2.5" / 3.5" shared
Network / Transport Protocol
TCP/IP, AppleTalk, LPR/LPD, FTP
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP)
Firewall protection, wake on LAN (WOL), E-mail alert, print server, firmware upgradable, MySQL server, web server, backup server, file sharing, Advanced Data Streaming (ADS), SSH support, iTunes server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server
DLNA CERTIFIED
Expansion Bays
10 (total) / 10 (free) x hot-swap - 2.5" / 3.5"
4 x USB 2.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45
FCC Class A certified, RoHS, BSMI Class A
TAA Compliant
Internal power supply
88 Watt
Software Included
Drivers & Utilities
TAA Compliant
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
39.3 dBA
