Synology DS415+ 12TB-Red 4 Bay NAS
Quicklinx: B0H8WS00 Mfr#: DS415+/12TB-RED
  • Atom
The DS415+ NAS solution has CPU with an AES-NI hardware encryption engine, a floating-point unit, as well as DDR3 RAM. The drive bays accommodate huge amounts of storage capacity, while the USB 3.0, USB 2.0, and eSATA ports allow users to connect and access a range of external storage devices. Dual LAN ports support failover and link aggregation, thus improving resiliency and potential throughput.
DS415+ supports Synology high availability (SHA), harnessing an active and a passive server into one cluster, mirroring written data between the two units. Should the main server malfunction, the passive server immediately kicks in and takes over all running services and data. Synology Hybrid RAID allows you to optimize usage and get the most out of your hard drives, while also keeping your storage safe with data redundancy.
  • A powerful and secure box
  • Excellent performance while safeguarding data
Synology Disk Station DS415+ - NAS server - 12 TB - TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
12 TB
Max Supported Capacity
24 TB
4 (installed) / 4 (max)
20.3 cm x 23.32 cm x 16.5 cm
2.05 kg ()
1 x Intel Atom 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
4 x 3 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
40
RAM
2 GB
Storage Operating System
Synology DiskStation Manager
TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
12 TB
24 TB
20.3 cm
23.32 cm
16.5 cm
2.05 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
RAM
2 GB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap - 3.5"
4 x 3 TB
Interface Type
SATA 6Gb/s
Buffer Size
64 MB
Network / Transport Protocol
DNS
Network Services Compatibility
Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP)
Wake on LAN (WOL), Syslog support, High Availability, Access Control List (ACL) support, RADIUS support, iTunes server, DNS server, Link Aggregation Control Protocol (LACP), VPN Server
DLNA CERTIFIED
Security DVR
40
Compression Format
MJPEG, H.264
Image Resolution
1920x1080, 2048x1536, 1280x800, 2591x1944
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x USB 2.0 - Type A , 1 x eSATA
2 x network cable
Built-in 2 cooling fans, Citrix Ready, scheduled power on/off, VMware Ready
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
External power adapter
46.2 Watt
Power Provided
100 Watt
Software Included
iTunes Server, RADIUS Server
TAA Compliant
5 °C
35 °C
5 - 95%
Sound Emission
20.2 dBA
