Robust NAS, unparalleled productivity
DS215+ is an all-in-one 2-bay NAS server offering high performance, energy efficiency, and complete business features in a network attached storage solution. Designed for multitasking applications, DS215+ helps small and medium businesses centralize backup, protect critical assets, and share files quickly and efficiently.
Dual-core CPU brings high performance
With dual-core CPU and Link Aggregation enabled, DS215+ delivers superior performance over 209 MB/s reading and 139 MB/s writing speed under RAID1 configuration in a Windows® environment1, while the 1GB RAM significantly increases DS215+'s multitasking power.
Hardware encryption engine enhances encrypted files transfer speeds
DS215+ is equipped with an encryption engine which offloads the encryption calculation tasks from the main CPU. Thus, the CPU is free for other important tasks, producing a considerable increase in throughput. DS215+ delivers encrypted data transmission speeds twice as fast as its predecessor - delivering an average of over 145 MB/s reading and 71 MB/s writing.
Dual LAN with failover and Link Aggregation support
Equipped with two Gigabit LAN ports featuring failover and Link Aggregation support, DS215+ ensures continual network service in case one LAN connection fails, and enhances connection speeds beyond the limits of a single cable or port. By supporting Adaptive Load Balancing, DS215+ allows you to benefit from failover and load balancing without a pricey switch. Active-standby, 802.3ad dynamic, and Balanced XOR are supported as well.
USB 3.0 and eSATA ensure speedy transfers to external storage
DS215+ boasts USB 3.0 and eSATA ports to connect to various kinds of external storage devices, while ensuring fast and efficient file transfer speeds. USB 3.0 support offers transfer speeds of up to 5 Gbps (about 10 times faster than USB 2.0), taking less time to transfer data to external hard drives and reducing power consumption.
Easy hard drive installation and hot-swappable support
For friendly and effortless hard drive installation, DS215+ features screwless drive bay design and hot-swappable support, allowing users to install 3.5" hard drives without a screwdriver. Installing and replacing drives is easier than ever.
Award winning OS - DiskStation Manager
Synology DiskStation Manager (DSM) is a sleek, browser-based operating system running on every DiskStation and RackStation, which makes managing your Synology NAS a breeze. Featuring an intuitive user interface, DSM makes accessing and sharing your data smarter and simpler. Synology's Package Center lets you download and install useful add-on packages designed specifically for individual or business needs, meaning you can enjoy more entertainment in your life or better productivity at work.
Ultimate file center
File Station is a fast and secure feature for sharing and managing your files stored on DS215+. Just drag-n-drop and upload data from Mac or PC. Advanced filters make it easy to search for documents, photos, or videos. With built-in FTP or email clients, DS215+ lets you organize and share files through an advanced web application effortlessly. You can even share files and folders with others by simply sending a link. Files can be reached on mobile devices via the companion mobile app DS file. HTTPS, SSL/TLS encryption, and link expiry dates also ensure file sharing over the Internet is highly secure
The most compatible sharing
Enjoy seamless files sharing across Windows®, Mac®, and Linux® platforms as DS215+ offers comprehensive network protocol support including FTP, SMB2, AFP, NFS and WebDAV. With Windows AD and LDAP integration, DS215+ can fit effortlessly into any existing network environment - there is no need for IT administrators to maintain two sets of credentials. You also won't worry about missing files with the Recycle Bin feature which is supported on AFP, CIFS, File Station, and WebDAV. All files deleted in a shared folder will be automatically moved into the Recycle Bin.
Fit into business environments easily
With the support of Windows AD, LDAP, and Domain Trust, DS215+ enables seamless account integration. The User Home feature can automatically create a "home" folder for every user account to minimize the administrator's effort in repeatedly creating "home" folders for all accounts. Windows ACL support on DS215+ allows IT administrators to fine tune access controls and set up privileges to files and folders on DS215+ through the familiar Windows user interface. With compatibility for major protocols, DS215+ can eliminate server configuration overhead and enhance IT administrators’ efficiency
All-in-One server
Offering rich office applications, DS215+ can serve as your multi-function server. With add-on packages Mail Server and Mail Station, DS215+ can become a dedicated mail server, and let you enjoy complete webmail service. DS215+ can become a VPN server or VPN client. The comprehensive VPN service let you access resources remotely while maintaining security protocols. As a printer server, DS215+ minimizes businesses' operating costs by sharing printing resources throughout the office. Administration and network tools, such as DNS Server, Directory Server, RADIUS Server, DHCP Server, and Log Center help you manage IT deployment and policies more efficiently. Maximize resource utilization with DS215+!
Increase business productivity with cloud solutions
With comprehensive cloud solutions, DS215+ lets you create your own private cloud easily. Cloud Station is the perfect package to sync files across multiple devices. Files can be edited in offline mode and later synced to Cloud Station, which keeps up to 32 historical versions, allowing you to restore a file back to previous version or recover deleted files. With the mobile app DS cloud, any change made to a file is automatically synced to your smartphones and tablets. For distributed enterprises, Synology's 2-way sync between different DiskStations ensures employees at different locations share the same information in real-time. IT administrators can handpick individual folders that they want to sync to different devices, manually or automatically based on file format and size. Folders synced by Cloud Station can be encrypted on DSM — no one will be able to access its content without your private key.
Secure your data
DS215+ offers advanced security measures to protect you from potential security holes. Security Advisor analyzes system settings, password strength, network preferences and removes any possible malware. AppArmor blocks malicious programs from accessing unauthorized system resources. You can also customize the trust level in Package Center to avoid installing packages from untrusted sources, safeguarding your NAS from unknown or tampered files. In addition, DS215+ provides other security add-ons, such as AES encryption, 2-Step verification
DS215+ is equipped with an encryption engine which offloads the encryption calculation tasks from the main CPU. Thus, the CPU is free for other important tasks, producing a considerable increase in throughput. DS215+ delivers encrypted data transmission speeds twice as fast as its predecessor - delivering an average of over 145 MB/s reading and 71 MB/s writing. -
Equipped with two Gigabit LAN ports featuring failover and Link Aggregation support, DS215+ ensures continual network service in case one LAN connection fails, and enhances connection speeds beyond the limits of a single cable or port. -
DS215+ boasts USB 3.0 and eSATA ports to connect to various kinds of external storage devices, while ensuring fast and efficient file transfer speeds. USB 3.0 support offers transfer speeds of up to 5 Gbps (about 10 times faster than USB 2.0), taking less time to transfer data to external hard drives and reducing power consumption. -
- Synology Disk Station DS215+ - NAS server - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Max Supported Capacity
- 16 TB
- Installed Devices / Modules Qty
- 0 (installed) / 2 (max)
- 10.35 cm x 23.2 cm x 15.7 cm
- 1.69 kg ()
- Processor
- 1 x 1.4 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s / eSATA RAID RAID 0, 1, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 25
- RAM
- 1 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Synology DiskStation Manager
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
- TAA Compliant
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 16 TB
- 10.35 cm
- 23.2 cm
- 15.7 cm
- 1.69 kg ()
Processor / Memory
- Processors Installed
- 1 x 1.4 GHz
- Number of Cores
- Dual-Core
- RAM
- 1 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s / eSATA
- RAID Level
- RAID 0, RAID 1, JBOD
- Data Link Protocol
- TCP/IP, PPTP, PPPoE, iSCSI, LPR/LPD, SMTP, FTP, DHCP, POP3, IMAP, DDNS
- Remote Management Protocol
- SNMP, Telnet, IPP, HTTP, HTTPS, SSH
- Network Services Compatibility
- DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
- Firewall protection, hardware encryption, VPN support, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, MySQL server, web server, backup server, download client, file sharing, Access Control List (ACL) support, Advanced Data Streaming (ADS), SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, bandwidth control, surveillance station, DLNA Media Server, eMule client, e-mail notification, VPN Server
- Encryption Algorithm
- SSL, TLS
- DLNA CERTIFIED, UPnP
Security DVR
- 25
- Expansion Bays
- 2 (total) / 2 (free) x hot-swap - 2.5" / 3.5"
- 2 x USB 3.0 - Type A , 1 x eSATA , 2 x Ethernet 1000Base-T - RJ-45
- Cables Included
- 2 x network cable
- Wake on LAN, built-in cooling fan
- FCC Class B certified, RoHS, BSMI Class B
- TAA Compliant
- Power Device
- External power adapter
- Voltage Required
- 20.77 Watt
- Power Provided
- 72 Watt
- Software Included
- Drivers & Utilities
- OS Required
- TAA Compliant
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 5 - 95%
