Synology DiskStation DS213j is a budget-friendly 2-bay NAS server for small offices and home use, specifically designed to provide a solution for file storage and sharing with data protection for your home environment with low power consumption, quiet operation and reliability. Running on DiskStation Manager (DSM) operating system, it delivers ease of use and variety of features.
- Synology Disk Station DS213J - NAS server - 4 TB - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 4 TB
- Max Supported Capacity
- 8 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 10 cm x 22.55 cm x 16.5 cm
- Processor
- 1 x 1.2 GHz
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 2 TB SATA 3Gb/s
- Networking
- Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 5
- RAM
- 512 MB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
- TAA Compliant
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 4 TB
- 8 TB
- 10 cm
- 22.55 cm
- 16.5 cm
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- 1 x 1.2 GHz
- RAM
- 512 MB DDR3
Storage Controller
- RAID - internal
- Interface Type
- SATA 3Gb/s
- Data Transfer Rate
- 300 MBps
- Max Storage Devices Qty
- 2
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD
- Capacity
- 2 x 2 TB
- Interface Type
- SATA 3Gb/s
- 300 MBps
- Data Link Protocol
- TCP/IP, PPTP, PPPoE, iSCSI, FTP, DHCP, DNS, DDNS
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
- Firewall protection, VLAN support, Syslog support, print server, IPv6 support, backup server, download client, Access Control List (ACL) support, RADIUS support, iTunes server, DHCP server, SMS alert, e-mail server, surveillance station, DNS server, cloud backup, VPN Server
- Encryption Algorithm
- SSL, TLS
- DLNA CERTIFIED
Security DVR
- 5
- Expansion Bays
- 2 (total) / 0 (free) x internal - 2.5" / 3.5"
- 2 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), wake on LAN, built-in cooling fan
- FCC Class B certified, RoHS, BSMI Class B
- TAA Compliant
- Power Device
- External power adapter
- Voltage Required
- 19.82 Watt
- Software Included
- Drivers & Utilities, Synology Assistant, Synology Data Replicator
- OS Required
- TAA Compliant
- Limited warranty - 2 years
- 15 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 17 dBA
