Enterprise Storage Drives for Synology Systems
Synology HAT5300 HDD offers class-leading performance thanks to tight integration with DSM and Synology hardware. With over 300,000 hours of in-house validation testing and backed by Synology’s 5-year limited warranty, the HAT5300 series brings unmatched reliability to Synology deployments.
Consistent Performance Scaling
Through testing and optimizations, HAT5300 series HDD has been tuned to deliver up to 23% higher sustained sequential read performance in demanding multi-user environments.
Rigorous Validation
Over 300,000 hours of stress testing with Synology devices ensure that HAT5300 drives can withstand even the most demanding enterprise environments and deliver highly reliable performance.
Effortless Firmware Updates
Automatic firmware updates through DSM mean that HAT5300 drives always benefit from the latest enhancements.
Durability for 24/7 Environments
HAT5300 series HDD is backed by a 2.5 million hour MTTF rating, workload support of 550 TB per year, and persistent write cache technology to minimize data corruption in the event of sudden power loss.
- Synology HAS5300 - hard drive - 16 TB - SAS 12Gb/s
- Hard drive - internal
- Capacity
- 16 TB
- Form Factor
- 3.5"
- Interface
- SAS 12Gb/s
- Data Transfer Rate
- 1.2 GBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- NAS compatible, Enterprise, workload up to 550 TB per year
- 101.85 mm x 147 mm x 26.1 mm
- 720 g
- 5-year warranty
- Designed For
- Synology SA3200D, SA3400, SA3600; High Density HD6500; RackStation RS18016xs+, RS18017XS+; Unified Controller UC3200
- Capacity
- 16 TB
- Form Factor
- 3.5"
- Interface
- SAS 12Gb/s
- Buffer Size
- 256 MB
- Bytes per Sector
- 512
- 101.85 mm
- 147 mm
- 26.1 mm
- 720 g
Performance
- Drive Transfer Rate
- 1.2 GBps (external)
- Internal Data Rate
- 262 MBps
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 2,500,000 hours
Expansion & Connectivity
- 1 x SAS 12 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 4.46 Watt (idle) , 5.12 Watt (random read/write)
- Limited warranty - 5 years
- Designed For
- Synology SA3200D, SA3400, SA3600 , Synology High Density HD6500 , Synology RackStation RS18016xs+, RS18017XS+ , Synology Unified Controller UC3200
