StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter
Quicklinx: C4L7WS00 Mfr#: PEX4M2E1
Type: Interface Adapter
Compatibility: PC
Interface: PCI Express
21 In Stock
£23.56 ex VAT
£28.27 inc VAT
Connect a PCIe M.2 SSD (NVMe or AHCI) to your computer through PCI Express for ultra-fast data access. Get ultra-fast data access by adding a PCIe M.2 SSD to your existing computer. This adapter lets you add a high-speed, 4-lane M.2 SSD (PCIe-based), such as a Samsung 950 Pro or Samsung SM 951, to a PC with an available x4 PCI Express expansion slot. You can mount the PCIe M.2 drive directly onto the adapter, giving you an easy and convenient way to improve your system performance and expand overall internal storage.
The expansion card lets you take full advantage of the fast performance and compact size of PCIe M.2 internal solid-state drives. The adapter connects directly to your computer motherboard to support an M.2 PCIe-based SSD (NVMe or AHCI) through ultra-fast x4 PCIe. The adapter is compatible with PCIe 3.0 motherboards and is also backward compatible with PCIe 2.0 and PCIe 1.0. With the M.2 PCIe based drive in place, the adapter gives your computer a significant speed boost.
The adapter supports PCIe 3.0 x4 NVMe (M Key) and PCIe-AHCI M.2 SSDs including 2242, 2260, 2280, and 22110 drives. The expansion slot adapter supports the most common drive sizes including 110 mm, 80 mm, 60 mm and 42 mm.
The expansion card is equipped with a full-profile bracket and includes a half-height/low-profile bracket, for installation in small form-factor computers.
StarTech.com M2 PCIe SSD Adapter - x4 PCIe 3.0 NVMe / AHCI / NGFF / M-Key - Low Profile and Full Profile - SSD PCIe M.2 Adapter (PEX4M2E1) - interface adapter - M.2 Card - PCIe x4
Interface adapter - plug-in card
Bus Type
PCIe x4
Red
Supported Form Factor
Expansion Slot to M.2
Expansion Bays
1 x internal - M.2
Hard Drive Form Factor Compatibility
M.2
M.2 Card
Supported Devices
Solid state drive
2.2 cm x 17.8 cm x 8 cm
42.2 g
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
M.2
Host Bus
PCIe x4
Red
Storage Controller
M.2 Card
Supported Devices
Solid state drive
Bays
1 x internal - M.2
Low-profile bracket, full-height bracket, half-height bracket
FCC, RoHS, WEEE, RCM
2.2 cm
17.8 cm
8 cm
42.2 g
5 °C
50 °C
15 - 90%
C4L7 StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £18.53
C4L7 StarTech.com M.2 NGFF to SATA Adapter In Stock £23.25
C4L7 StarTech.com 2x M.2 SSD Controller - PCIe In Stock £56.93
C4L7 StarTech.com Dual M.2 NGFF SATA Adapter w/ RAID - 2x M.2 SSDs to 2.5in SATA In Stock £35.63
C4L7 StarTech.com M.2 RAID Controller Card PCIe In Stock £65.07
C4L7 StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £23.56
C4L7 StarTech.com 3PT M.2 SSD Card - PCIe 3.0 In Stock £32.12
C4L7 StarTech.com U.2 2.5" NVMe SSD Adapter In Stock £21.56
C4L7 StarTech.com M.2 SATA Raspberry Pi Adapter In Stock £20.34
C4L7 StarTech.com U.2 to PCIe Adapter -SFF-8639 In Stock £35.34
C4L7 StarTech.com M.2 to U.2 Adapter In Stock £26.40
C4L7 StarTech.com M.2 NVMe SSD Enclosure for PCIe SSDs - USB 3.1 Gen 2 Type-C In Stock £55.05
C4L7 StarTech.com M.2 NVMe PCIe SSD Enclosure - IP67 water/dust resistance In Stock £73.58
C4L7 StarTech.com USB-C 10Gbps to M.2 NVMe or M.2 SATA SSD Enclosure In Stock £59.24
C4L7 StarTech.com USB PCIE/SATA M.2 Enclosure In Stock £54.80
C4L7 StarTech.com Dual M.2 PCIe SSD Adapter Card In Stock £70.75
C4L7 StarTech.com M.2 to U.3 Adapter/Converter In Stock £34.61
Compatibility: PC
