Discover a high-quality solution for your high-resolution display needs with the StarTech.com 2m DisplayPort 2.1 Cable. This VESA-Certified, DP40 DP 2.1 Cable is engineered to deliver a premium audiovisual experience, supporting up to 40 Gbps data transfer rates, HDR10, and Variable Refresh Rate (VRR). Whether you're gaming, streaming, or engaging in high-definition video playback, this cable is designed to meet your needs with support for 8K60Hz, 4K144Hz, and 1440p at 240Hz resolutions.
Constructed for durability, it features a 10,000 insertions lifespan, 600 bend lifespan, and strain relief, ensuring it withstands the rigors of regular use. The inclusion of EMI protection and halogen-free materials not only ensures the safety of your setup but also contributes to a more sustainable environment. With support for FreeSync and G-Sync, enjoy seamless, tear-free visuals that transform your viewing experience. Choose the StarTech.com DisplayPort cable for a reliable, high-quality connection that brings your content to life.
Enhanced durability
Designed for longevity, this 2m DisplayPort 2.1 Cable boasts a 10,000 insertions lifespan and a 600 bend lifespan, ensuring reliable performance through extensive use. The ABS housing and strain relief further enhance its durability, making it a robust choice for your connectivity needs. -
Superior audiovisual experience
Experience high-quality audio and visual quality with support for 32 audio channels, HDR10, and Variable Refresh Rate (VRR). Whether it's gaming or streaming, the inclusion of FreeSync and G-Sync support provides a smooth, tear-free experience, elevating your viewing experience. -
High-speed connectivity
Achieve high data transfer rates of up to 40 Gbps with this VESA-Certified DP40 DP 2.1 Cable. It supports resolutions up to 8K60Hz, 4K144Hz, and 1440p at 240Hz, making it ideal for high-resolution gaming, detailed graphics work, and ultra-high-definition video streaming.
- StarTech.com 2m DisplayPort 2.1 Cable, VESA-Certified, DP40 DP 2.1 Cable - DisplayPort cable - DisplayPort to DisplayPort - 2 m
- DisplayPort cable
- Technology
- Shielded
- Passive cable, 8K60Hz support, 4K144Hz support, 1440p support 240Hz, up to 40 Gbps data transfer rate, UHBR10, HDR support, strain relief, EMI protection, halogen free, copper conductors, DisplayPort Multi-Stream Transport (MST), 32 audio channels, HDR10 support, ABS housing, G-Sync support, FreeSync support, Variable Refresh Rate (VRR), 600 bend lifespan, 10000 insertions lifespan
- Length
- 2 m
- Connector
- 20 pin DisplayPort - male - latched
- Connector (Second End)
- DisplayPort 2.1
- Black
- 2-year warranty
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 30
- Plated Connector
- Nickel
- Length
- 2 m
- Outside Diameter
- 6.5 mm
- Black
- 106 g
- Connector
- DisplayPort 2.1, RoHS, WEEE, VW-1, HDCP 2.2, DSC 1.2a, VESA DP40
- Shipping Width
- 22.5 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 1.5 cm
- Shipping Weight
- 120 g
- 2-year warranty
StarTech.com USB C to DP Adapter - 8K/4K | In Stock | £23.32 |
StarTech.com VESA-Certified DP 2.1 Cable | In Stock | £16.23 |
