StarTech.com USBC Multiport Adapter 4K HDMI
Quicklinx: GJK2WS00 Mfr#: DKT30CHSDPD
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Grey
22 In Stock
£30.13 ex VAT
£36.15 inc VAT
USB Type-C Multiport Adapter | 4K @ 30Hz HDMI | 2x USB-A | SD & MicroSD Card Reader | 100W Power Delivery Passthrough
This USB-C multiport adapter with HDMI turns your MacBook Pro, Dell XPS, or other USB-C laptops into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K HDMI video output, two USB 3.2 Gen 2 Type-A (10Gbps) ports, and a USB Type-C port (power/data), all through one connection to your laptop's USB-C or Thunderbolt 3 port. Plus, it offers advanced charging through USB Power Delivery 3.0 and an extra-long attached 12-inch (30 cm) host cable for an extended reach to offer more set up flexibility.
Enhance Productivity
The portable docking station connects your laptop to a 4K 30Hz HDMI monitor (3840 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor.
Connect Your Devices
The USB-C to USB 3.2 Gen 1 hub gives you two USB-A ports one and a USB-C port (shared power/data) to connect your latest and legacy USB devices.
Built-In SD Card Reader
Access your multimedia content with ease. The multiport adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD (uSD) cards.
Charge Your Laptop and Peripherals
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power).
The DKT30CHSDPD is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Note: To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
  • Enhance Productivity
  • Connect Your Devices
  • Built-In SD Card Reader
  • Charge Your Laptop and Peripherals
    With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power). The DKT30CHSDPD is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note:?To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
StarTech.com USB C Multiport Adapter, USB-C to 4K 30Hz HDMI, 100W Power Delivery Pass-through, SD/MicroSD Slot, 3-Port USB 3.0 Hub, USB Type-C Mini Dock, 12" (30cm) Long Attached Cable - Thunderbolt 3 Compatible (DKT30CHSDPD) - docking station - USB-C / Thunderbolt 3 - HDMI
Docking station
Docking Interface
Video Interfaces
HDMI
5.2 cm x 1.4 cm
98 g
Power Provided
3-year warranty
Docking station
5.2 cm
1.4 cm
98 g
Video
Max Resolution Details
3840 x 2160 - 30 Hz , 3440 x 1440 - 60 Hz
USB 3.2 Gen 2
Expansion Slots
1 (total) / 1 (free) x SD / MMC Memory Card , 1 (total) / 1 (free) x microSD
1 x USB 3.1 Gen 2 - 9 pin USB Type A , 1 x SuperSpeed USB 3.0 with Battery Charging 1.2 - 9 pin USB Type A , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C
Input Device
SD card reader, microSD card reader
1 x USB-C cable - integrated - 30 cm
100W power delivery
FCC, RoHS, USB Battery Charging Specification Rev. 1.2, USB Power Delivery 3.0
Android, Google Chrome OS, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple iPadOS, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Windows 8 / 10 / 11, Apple macOS Ventura 13.0
Limited warranty - 3 years
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
134 g
70 °C
GJK2 StarTech.com USB C Dock DP 4K30Hz or VGA In Stock £115.87
Device Type: Laptop
Colour: Grey
