StarTech.com USB VGA Console Extender over CAT5 UTP (500 ft)
Quicklinx: 6BDKWS00 Mfr#: SV565UTPUGB
Hurry, only 3 left in stock!
£167.61 ex VAT
£201.13 inc VAT
This USB VGA KVM console extender lets you control a server, computer or multiple computers (connected through KVM switch) over a standard Cat5 or Cat6 UTP network cable connection, at distances of up to 500ft away. PC connection cables are included with this product for a ready out of the box solution.
You can use your existing keyboard, mouse, and monitor to access both the server room and your office computer, saving space and avoiding the need for a dedicated remote console by allowing you to switch between workstation view and KVM view at the remote location.
The USB VGA console extender is designed to provide long lasting, reliable operation.
  • Distance coverage
    The KVM extender allows for keyboard, mouse, and video signals to be transmitted over a distance of up to 150 m, offering flexibility in placement.
  • Video quality
    With a maximum supported video resolution of 1024 x 768, this extender delivers clear images suitable for various display needs.
  • Compatibility
    Featuring VGA, USB keyboard, and USB mouse interfaces, the extender is engineered for easy connection with multiple devices.
  • Compliance standards
    Aligning with FCC and RoHS standards, this device ensures adherence to safety and environmental requirements.
  • Power management
    The KVM extender is equipped with an external power adapter, facilitating a straightforward setup and efficient operation.
StarTech.com USB VGA KVM Console Extender over CAT5 UTP - KVM extender
KVM extender
External
United Kingdom
Transmission Medium
CAT 5
Max Transfer Distance
150 m
15.5 cm x 7.5 cm x 2 cm
299 g
KVM extender
External
United Kingdom
Wired
Max Resolution
1024 x 768
150 m
1 x USB mouse , 1 x USB keyboard , 1 x VGA - HD-15 , 1 x KVM - HD-15
2 x keyboard / mouse / video cable
FCC, RoHS
External power adapter
15.5 cm
7.5 cm
2 cm
299 g
6BDK StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £10.69
6BDK StarTech.com DC Power Adapter - 9V, 2A In Stock £12.21
