StarTech.com USB to SATA External Hard Drive Docking Station for 2.5in SATA HDD
Quicklinx: 6Q9KWS00 Mfr#: SATDOCK25U
Enable external, hot-swap access to 2.5in SATA drives from a portable mini USB2.0 drive dock.
The SATDOCK25U Hard Drive Docking Station provides full, instant access to any 2.5in SATA (SATA, SATA II, SATA III) hard drive or solid state drive - without having to mount the hard drive in a computer or install it in an enclosure!
This highly compact HDD dock offers the portability needed to add simple external storage to virtually any USB-capable computer, making it a definite asset to have on hand to connect external (bare) hard drives even in mobile computing applications. Plus, its small form factor design requires minimal space on a desktop or work bench. Large capacity drives (tested with up to 1TB) can be used to greatly enhance your computer's storage/backup capabilities.
Simply insert a 2.5in SATA hard drive or SSD into the dock, then connect the hard drive dock to a host computer through USB 2.0. To uninstall or swap the hard drive, simply disconnect the USB cable and remove the drive from the dock!
In addition to providing a fast convenient way to access or recover data from a mobile 2.5in drive this dock is completely USB powered, so no power adapter is required. The HDD Dock supports plug and play hard drive installation on most operating systems, and offers data transfer speeds of up to 480Mbps - a convenient alternative to external hard drive enclosures that saves the time needed to prepare the drive for conventional installation.
StarTech.com USB to SATA External Hard Drive Docking Station for 2.5in SATA HDD - SATA Hard Drive Dock - HDD docking station - SATA 3Gb/s - USB 2.0
HDD docking station - external
Bays
1
Bus Type
USB 2.0
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Max Storage Devices Qty
1
Product Material
Plastic
Power Source
Included AC adapter
Linux, Maxtor NAS OS 2.0 or later, Microsoft Windows 2000/ME/XP/Vista/7
2.5 cm x 8.2 cm x 3.6 cm
30 g
P/N: USBDUP15, USBDUPE115, USBDUPE17
Bays
1
2.5"
Host Bus
USB 2.0
Product Material
Plastic
Storage Controller
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
1
JMicron JM20329
Bays
1 x internal - 2.5"
1 x SATA 3Gb/s - SATA power , 1 x SATA 3Gb/s - SATA
1 x USB 2.0 - mini-USB Type B
1 x USB cable - external
Tested with up to 1TB 5400 RPM hard drives
Plug and Play, FCC, RoHS
Power Source
Included AC adapter
Power adapter
2.5 cm
8.2 cm
3.6 cm
30 g
5 °C
80 °C
0 - 90%
6Q9K StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.33
6Q9K StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £14.68
