StarTech.com uSB to RS-232 Serial DB9 Adaptor
Customer rating: 5.0* (Write a review)
Quicklinx: 2ZWWWS00 Mfr#: ICUSB232
Add one serial RS-232 port to any laptop or computer with a USB port. The StarTech.com ICUSB232 1ft USB to DB9 RS232 Serial Adapter Cable lets you connect DB9 RS232 serial devices to your Mac or PC laptop or desktop computer through a USB port, as though the computer offered an onboard DB9M connector.
A cost-effective solution that bridges the compatibility gap between modern computers and legacy serial peripherals, as well as offering compatibility with nearly all PLC Brands (AllenBradley, Siemens, Modicon, Servos, Indramat, Siemens, AB, etc.).
StarTech.com USB to DB9 Serial Adapter Cable - serial adapter - USB - RS-232
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232
RS-232
Data Transfer Rate
115.2 Kbps
Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 2000, Microsoft Windows Millennium Edition, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
P/N: ST4205USBGB, ST4205USBEU, ST4205READGB, ST4205READEU, ST4205USB, ST4205READ
Serial adapter
External
USB
Ports
RS-232
Wired
RS-232
Data Transfer Rate
115.2 Kbps
Status Indicators
Active
1 x RS-232 - 9 pin D-Sub (DB-9) - male - 1
1 x USB - 4 pin USB Type A
1 x serial cable (integrated) - 0.3 m
Limited warranty - parts and labour - 2 years
5 °C
0 - 80%
StarTech.com 3 Port USB 2.0 Hub & 16-in-1 Multi Media Memory Card Reader, 4 Port Silver USB 2.0 Hub
Resources
The following resources are available for the StarTech.com uSB to RS-232 Serial DB9 Adaptor
Customer reviews
Write a review for the StarTech.com uSB to RS-232 Serial DB9 Adaptor here!
Does exactly what it says on the tin!!
Reviewed by Matt. Review Posted 24/07/2006
Works exactly like you had a serial port built into your machine.... never had any problems and good value for money.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
This is the one to get
Reviewed by JJ. Review Posted 04/11/2006
I reviewed several for a client and this is the only one that worked flawlessly. Not the cheapest but the only one we'll be using in future.
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
Works well, but poor documentation
Reviewed by David Biggins. Review Posted 28/03/2009
The device itself works well once installed, although this took some time. The supplied instructions are for Windows 2000 only and even then refer to drivers not supplied on the CD-ROM. The CD-ROM itself is confusing having drivers for several devices none of which seemed to match the device exactly.
Trial and error finally got it working.
  • Overall 4*
  • Ease of use 3*
Read all 4 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
