Add a compact external memory card reader to any computer with a USB port. An ideal laptop or desktop accessory, this pocket-sized memory card reader connects to a computer through USB to support the most popular memory card formats, providing an all-in-one flash memory solution.
This multi-format memory card reader supports Memory Stick, MS Pro, MS Duo, MS Pro Duo, MS MG, MS Micro (M2), Micro SD, Mini SD, RS MMC/MMC 4.0, Ultra II SD, Extreme SD, Extreme II SD, T-Flash (no adapter required) and more, as well as high capacity cards such as SDHC and SDXC. Plus, this card reader is backward compatible with older card formats such as SD, to ensure you can access and write to your memory card without any hassles.
- StarTech.com USB Multi Media Memory Card Reader Adapter - card reader - USB 2.0
- Product Type
- Card reader - external
- Supported Memory Cards
- Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, miniSD, RS-MMC, TransFlash, microSD, Memory Stick Micro (M2)
- Host Interface
- USB 2.0
- Black
- 2-year warranty
- Designed For
- P/N: USBDUP12, USBDUP15, USBDUPE115, USBDUPE17
- Product Type
- Host Interface
- USB 2.0
- Black
- 193 mm
- 10 mm
- 41 g
Memory Card
- Capacity
- (max)
- Required Ports
- 1 x 4 pin USB Type A
- OS Required
- Microsoft Windows 98SE/2000/ME/XP, Apple MacOS 9.x or later, Microsoft Windows Vista
- FCC
- Limited warranty - 2 years
- Designed For
