StarTech.com USB C Video Adapter 4K 60Hz
Quicklinx: GTBDWS00 Mfr#: 122-USBC-HDMI-4K-VGA
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Grey
More than 50 In Stock
£47.25 ex VAT
£56.70 inc VAT
This USB-C Multiport Video Adapter offers a portable solution for connecting USB Type-C devices to HDMI and/or VGA displays, with up to 100W of Power Delivery.
  • Versatile Video Connectivity
    This Multiport Adapter supports a single HDMI display at resolutions up to 4K 60Hz, a single VGA display at resolutions of up to 1920x1200 60Hz or dual-mirrored HDMI and VGA displays at resolutions of up to 1080p. The 3.5mm audio port can be used for connecting speakers while presenting with a VGA projector/display, or headphones.
  • Extended Cable Length
    The adapter is equipped with an extra-long 12 inch (30cm) attached cable, providing an extended reach, to reduce port and connector strain on 2-in-1 devices, tablets, or laptops on risers/stands.
  • Power Delivery
    The USB C to HDMI and VGA Adapter is bus powered for easy use while traveling. Optionally, connect a USB-C power adapter and charge your laptop using the Power Delivery 3.0 pass-through feature, supporting up to 100W charging.
  • Connectivity for Any Laptop
    The USB Type-C Display Adapter is compatible with USB-C DisplayPort Alt-mode, Thunderbolt 3, and Thunderbolt 4 enabled laptops, Ultrabooks, Chromebooks, and MacBooks. Plug and play (driver/software free) compatibility with any operating system such as Windows, macOS, iPadOS, Chrome OS, and Linux. 122-USBC-HDMI-4K-VGA is backed for 3-years by StarTech.com, including free 24/5 multi-lingual technical assistance. Note: This adapter does not support MST or dual extended displays.
StarTech.com USB C Video Adapter, USB C to HDMI VGA Multiport Adapter w/ 3.5mm Audio Output, 4K 60Hz, HDR, 100W PD 3.0, USB C Monitor Adapter for Laptop, Thunderbolt 3/4 Compatible - USB C Display Travel Adapter (122-USBC-HDMI-4K-VGA) - docking station - USB-C / Thunderbolt 3 / Thunderbolt 4 - VGA, HDMI
Docking station
Docking Interface
Video Interfaces
VGA, HDMI
6 cm x 4.5 cm x 1.4 cm
41 g
Grey
Power Provided
3-year warranty
Docking station
6 cm
4.5 cm
1.4 cm
41 g
Enclosure Colour
Grey
Video
Max Resolution Details
3840 x 2160 - 60 Hz (HDMI only) , 1920 x 1200 - 60 Hz (VGA only)
1 x display / video - HDMI output - 19 pin HDMI Type A , 1 x display / video - VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB-C with Power Delivery (100 W) (power only) - 24 pin USB-C , 1 x audio - mini-phone stereo 3.5 mm
1 x USB-C cable - integrated - 30 cm
Active, DisplayPort Alt Mode, HDR support, 100W power delivery (pass-through), wide screen support
Plug and Play, RoHS, WEEE, HDCP 2.2, USB Power Delivery 3.0
Limited warranty - 3 years
Shipping Width
17 cm
Shipping Depth
14.2 cm
Shipping Height
3 cm
Shipping Weight
245 g
45 °C
GTBD StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £15.88
GTBD StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £20.72
Device Type: Laptop
Colour: Grey
