FLEXIBLE MULTI DISPLAY SETUP: USB 3.1 Gen 2 10Gbps Type-C/A dock supports dual or triple monitor setup (up to 3x 4K 60Hz), using any combination of the 3x DisplayPort 1.4 & 3x HDMI 2.0 w/ HDR ports.
85W POWER DELIVERY: Power & charge USB-C/Thunderbolt 3 workstation laptops/ultrabooks incl Lenovo X1 Carbon, ThinkPad P Series, Dell Latitudes, Precision, XPS 15, HP Spectre, ZBook & MacBook Pro 16.
UNIVERSAL DOCKING STATION: Hybrid dock includes combo 2-in-1 USB-C/USB-A USB-IF Certified host cable; DisplayLink dock supports up to 3 extended displays on Macbook Pro/Air with Intel processor or Apple M1 chip; compatible w/ Windows, macOS and Chrome OS.
6-PORT USB HUB: 4x USB-A (1x 10Gbps), 2x USB-C (1x 10Gbps), incl. 2x BC 1.2 fast charge always-on front ports; USB-C Gen 1 & USB-A laptops will only support downstream port speeds up to USB 5Gbps.
DEPLOYMENT READY: Docking station features a K-slot, 1m combo host cable, mounting holes, & MAC address changer for IT management; Gigabit Ethernet & headset ports; Windows, MacOS, Chrome OS.
- StarTech.com USB-C & USB-A Dock, Hybrid Universal Triple Monitor Laptop Docking Station w/ DisplayPort & HDMI 4K 60Hz, 85W Power Delivery, 6x USB Hub, Ethernet, Audio, USB 3.1 Gen 2 10Gbps - Multi-Monitor Dock (DK31C3HDPDUE) - docking station - USB-C - 3 x HDMI, 3 x DP - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- 3 x HDMI, 3 x DP
- 8.4 cm x 23.3 cm x 3.7 cm
- 365 g
- Grey, black
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 100/240 V 85 Watt Power Provided
- 3-year warranty
- Product Type
- Docking station
- 8.4 cm
- 23.3 cm
- 3.7 cm
- 365 g
- Enclosure Colour
- Grey, black
Video
- Max Resolution Details
- 4096 x 2160 - 60 Hz
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- 3 x USB 3.1 Gen 2 - 9 pin USB Type A , 1 x USB-C 3.1 Gen 2 - 24 pin USB-C , 1 x USB-C 3.1 Gen 1 (data only) - 10 pin USB-C , 3 x display / video - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 3 x display / video - 20 pin DisplayPort , 1 x headphone/microphone combo jack - mini-phone 3.5 mm , 1 x USB-C 3.0 - 24 pin USB-C , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A
- Cables Included
- 1 x USB-C/USB-A screw-lock cable - external - 1 m
- Security lock slot (cable lock sold separately), USB pass-through connector, UASP transfer protocol, Preboot Execution Environment (PXE) support, full duplex support, up to 3 monitors support, HDR support
- Security Slot Type
- Kensington security slot
- FCC, RoHS, USB Battery Charging Specification Rev. 1.2, DisplayPort 1.2, DisplayPort 1.4, UASP (USB Attached SCSI Protocol), USB Power Delivery 3.0
- Power Device
- Power adapter
- Voltage Required
- AC 100/240 V
- Power Provided
- 85 Watt
- OS Required
- Google Chrome OS, Apple MacOS X 10.6 - 10.12, Ubuntu 18.04, Ubuntu 20.04, Apple macOS 10.14 - 11.0, Apple macOS 12.0, Windows 8 / 8.1 / 10 / 11, Apple macOS 13.0
- Limited warranty - 3 years
- Shipping Width
- 9 cm
- Shipping Depth
- 25 cm
- Shipping Height
- 17.1 cm
- Shipping Weight
- 1.7 kg
- 0 °C
- 50 °C
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.37 |
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £9.78 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £10.86 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £14.12 |
StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 | In Stock | £25.84 |
StarTech.com 10m Active DisplayPort Cable - DP to DP M/M | In Stock | £91.66 |
StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 | In Stock | £16.29 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £10.55 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £9.82 |
StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla | In Stock | £9.06 |
StarTech.com Docking Station Mount - For StarTech.com Docks / Hubs - VESA | In Stock | £14.35 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £12.26 |
