StarTech.com USB-C to DP MST Hub - 3-Port
Quicklinx: D1VWWS00 Mfr#: MSTCDP123DP
12 In Stock
£53.09 ex VAT
£63.70 inc VAT
Use this adapter to connect three independent displays to a single USB Type-C port. This MST hub lets you connect three DisplayPort monitors to your USB-C computer. MST ensures hassle-free setup by natively working on any Windows device that supports DP alt mode over USB Type-C, such as models of Dell Precision, Dell XPS laptops and ASUS ROG GL752.
The MST hub also works with Thunderbolt 3 ports to provide Thunderbolt 3 to triple DisplayPort conversion. Plus with a lower price point than docks, MST offers a multi-monitor solution that's more cost-effective than a traditional laptop docking station.
The newest generations of laptops are more portable than ever. Unfortunately, this means you're left with fewer video outputs and a small integrated screen. This MST hub solves these problems by letting you connect three displays to a single USB-C port on your computer, which makes multitasking much easier.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display. This makes it easier to multitask and increase your productivity, which is perfect for creating an easy-to-dock hot-desk solution with a wireless keyboard and mouse peripheral set.
You can also mirror the same image onto multiple displays for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. 4K is supported by the latest A/V devices and delivers four times the resolution of 1080p.
Plus, because the MST hub can output high-definition 1080p, the MST hub is perfect for all high-resolution applications such as graphic design and medical imaging.
With this MST hub, you can use separate DP video adapters to connect HDMI, VGA or DVI displays, for compatibility with all of your existing monitors.
  • Multitasking Made Easy
    With devices becoming more portable than ever, you can be limited to fewer video outputs and confined to your small integrated screen. This MST hub solves that problem by enabling you to connect three displays to your USB-C computer, making multi-tasking much easier. Using this USB-C to DisplayPort splitter, you can mirror your display onto additional monitors or stream independent content to each display, which makes it the ideal accessory for travel or hot-desking.
  • Astonishing Picture Quality
    Multi-Stream Transport (MST) technology uses your existing video card to minimize the use of system resources while delivering UHD 4K resolutions for up to two monitors simultaneously. Plus, because the multi-monitor splitter can output HD 1080p on three independent displays, it's perfect for all high-resolution applications such as graphic design and medical imaging.
  • Hassle-Free Setup
    MST offers an easy setup, by natively working on any Windows device that supports DP Alt Mode over USB Type-C. This USB-C multi-monitor adapter is Thunderbolt 3 compatible and offers plug-and-play installation with no drivers or software required. Additionally, this DP MST hub is powered by the USB-C port, meaning no external power cords are necessary. MSTCDP123DP is backed by a StarTech.com 3-year warranty, and free lifetime technical support.
StarTech.com 3 Port Multi Monitor Adapter USB-C to 3x DisplayPort 1.2 Video Splitter USB Type-C to DP MST Hub, Dual 4K 30Hz or Triple 1080p, Compatible with Thunderbolt 3, Windows Only - Multi Stream Transport (MSTCDP123DP) - external video adapter
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
3 x DisplayPort (female connector)
3-year warranty
Bus Type
USB-C
Max Resolution
3840 x 2160
USB powered, HD/4k Ready
Microsoft Windows 7 / 8 / 8.1 / 10
Limited warranty - 3 years
D1VW StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.84
D1VW StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.86
D1VW StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.12
D1VW StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £16.29
D1VW StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £50.34
D1VW StarTech.com MST Hub - mDP to 2x DP In Stock £36.39
D1VW StarTech.com MST Hub - 2-Port DisplayPort In Stock £43.14
D1VW StarTech.com MST Hub - mDP to 4x DP In Stock £74.26
D1VW StarTech.com USB-C to VGA Adapter - White In Stock £21.61
D1VW StarTech.com mDP 1.2 to HDMI MST Hub In Stock £57.25
D1VW StarTech.com USB-C to HDMI Adapter In Stock £18.71
D1VW StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £32.27
D1VW StarTech.com 6ft USB-C to DisplayPort Cable In Stock £22.80
D1VW StarTech.com USB-C to DisplayPort MST Hub - 2-Port In Stock £40.58
D1VW StarTech.com 2m USB-C to HDMI Cable In Stock £31.44
D1VW StarTech.com USB-C to VGA - Power Delivery In Stock £23.19
D1VW StarTech.com USB-C to HDMI - Power Delivery In Stock £25.73
D1VW StarTech.com USB-C to 2x HDMI MST Splitter In Stock £34.11
D1VW StarTech.com USB-C to DP MST Hub - 3-Port In Stock £53.09
D1VW StarTech.com 3-Port USB C to HDMI MST Hub In Stock £46.85
D1VW StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.36
D1VW StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £25.52
D1VW StarTech.com USB C to DisplayPort Adapter - 8K 30Hz - HBR3 Adapter In Stock £14.02
D1VW StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £23.00
D1VW StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £24.95
D1VW StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £27.49
D1VW StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £29.45
D1VW StarTech.com Portable USB C to HDMI Adapter with Keychain In Stock £10.15
D1VW StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £32.41
