This USB-C multiport adapter with HDMI turns your MacBook Pro, Dell XPS, or other USB-C laptops into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K HDMI video output, two USB 3.2 Gen 2 Type-A (10Gbps) ports, and a USB Type-C port (power/data), all through one connection to your laptop's USB-C or Thunderbolt 3 port. Plus, it offers advanced charging through USB Power Delivery 3.0 and an extra-long attached 12-inch (30 cm) host cable for an extended reach to offer more set up flexibility.
The portable docking station connects your laptop to a 4K 30Hz HDMI monitor (3840 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor.
The USB-C to USB 3.2 Gen 1 hub gives you two USB-A ports one and a USB-C port (shared power/data) to connect your latest and legacy USB devices.
Access your multimedia content with ease. The multiport adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD (uSD) cards.
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power).
To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
Enhance Productivity
The portable docking station connects your laptop to a 4K 60Hz HDMI monitor (4096 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor. -
Connect Your Devices
The USB-C to USB 3.2 Gen 1 hub gives you two USB-A ports to connect your legacy USB devices. -
Built-In SD Card Reader
Access your multimedia content with ease. The multiport adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD (uSD) cards. -
Charge Your Laptop and Peripherals
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power). -
Reliable Network Connectivity
The Gigabit Ethernet port ensures reliable wired network access.
- StarTech.com USB C Multiport Adapter, USB-C to 4K 60Hz HDMI 2.0, 100W Power Delivery Pass-through, SD/MicroSD, 2-Port USB 3.0 Hub, GbE, USB Type-C Mini Dock, 12" (30cm) Long Attached Cable - Works w/Thunderbolt 3 (DKT30CHSDPD1) - docking station - USB-C / Thunderbolt 3 - HDMI - 1GbE
- Product Type
- Docking station
- Docking Interface
- Video Interfaces
- HDMI
- 35.2 cm x 3.4 cm x 1.4 cm
- 99 g
- Black, space grey
- Networking
- Gigabit Ethernet
- 3-year warranty
- Product Type
- Docking station
- 35.2 cm
- 3.4 cm
- 1.4 cm
- 99 g
- Enclosure Colour
- Black, space grey
Video
- Max Resolution Details
- 4096 x 2160 - 60 Hz
- Data Link Protocol
- USB 3.0
- Expansion Slots
- 1 (total) / 1 (free) x SD / MMC Memory Card , 1 (total) / 1 (free) x microSD
- 1 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x USB 3.2 Gen 1 with Fast Charging - 9 pin USB Type A , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x USB-C with Power Delivery (100 W) (power only) - 24 pin USB-C , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
- Input Device
- SD card reader, microSD card reader
- Cables Included
- 1 x USB-C cable - integrated - 30 cm
- DisplayPort Alt Mode, 100W power delivery, HDR support
- FCC, RoHS, DisplayPort 1.4, USB Power Delivery 3.0
- OS Required
- Android, Google Chrome OS, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple iPadOS, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Windows 8 / 10 / 11, Apple macOS Ventura 13.0
- Limited warranty - 3 years
- Shipping Width
- 10 cm
- Shipping Depth
- 18 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 180 g
- 0 °C
- 70 °C
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.37 |
StarTech.com USB C Multiport Adapter, 4K | In Stock | £34.69 |
StarTech.com USB C Multiport Adapter 4K | In Stock | £49.51 |
StarTech.com USBC Multiport Adapter 4K 60Hz | In Stock | £82.20 |
StarTech.com USB C Multiport Adapter 2 HDMI | In Stock | £73.52 |
StarTech.com USBC Multiport Adapter 4K 60Hz | In Stock | £79.09 |
StarTech.com USB-C Multiport Adapter | In Stock | £75.53 |
StarTech.com USB C Multiport Adapter | In Stock | £108.26 |
StarTech.com USB-C Multiport Adapter, HDMI | In Stock | £35.73 |
StarTech.com USB-C Multiport Adapter, HDMI | In Stock | £30.40 |
StarTech.com USB-C Triple Monitor Docking Station | In Stock | £180.53 |
StarTech.com USB-C Multiport Adapter - HDMI/DP | In Stock | £74.24 |
StarTech.com USB-C Multiport Adapter - HDMI/VGA | In Stock | £33.39 |
StarTech.com USB-C Speakerphone Dock | In Stock | £96.47 |
StarTech.com USB-C Triple-Monitor Adapter | In Stock | £93.92 |
StarTech.com USB-C/USB-A Multiport Adapter | In Stock | £51.75 |
