StarTech.com USB-C Multiport Adapter 2xDP
Quicklinx: DXYXWS00 Mfr#: DK30C2DAGPD
This USB-C multiport adapter turns your Windows laptop into a portable workstation. The USB-C to dual Display Port adapter connects your USB-C laptop to two DisplayPort monitors, letting you power through work faster or make presentations with different views on two displays. It gives you two USB-A ports, a Gigabit Ethernet port, a DP Alt Mode Switch, and laptop charging.
Through 100W?Power Delivery?3.0,?the?USB Type-C to DisplayPort adapter powers itself as well as your laptop and any attached peripherals, with up to 85W laptop charging when connected to a USB-C power adapter.?PD?3.0 features Fast Role Swap to prevent USB data disruption when?you?unplug?the power adapter to?switch?power sources (USB-C?power adapter to?bus power).
The USB-C video adapter extends your laptop screen to?dual DisplayPort displays. Using the DP Alt Mode switch, you can choose between higher display resolution or faster USB speed to meet your needs, for desktop or portable use. Choose between: dual 4K30 (or single 4K60) resolution with USB 2.0 speed, or dual 1080p (or single 4K30) resolution with USB 3.0 speed.
StarTech.com USB C Dock, 4K Dual Monitor DisplayPort, Mini Laptop Docking Station, 100W Power Delivery Passthrough, GbE, 2-Port USB-A Hub, USB Type-C Multiport Adapter 3.3' Cable, Dual DP - Portable USB-C Dock (DK30C2DAGPD) - docking station - USB-C - 2 x DP - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
2 x DP
6 cm x 12 cm x 1.18 cm
200 g
Gigabit Ethernet
3-year warranty
P/N: ARMBARDUO, ARMBARDUOV, ARMDUAL, ARMDUAL30, ARMDUALV, ARMSLIMDUO
Docking station
6 cm
12 cm
1.18 cm
200 g
Enclosure Colour
Video
Max Resolution Details
4096 x 2160 - 60 Hz
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
1 x USB 3.1 Gen 1 - 24 pin USB-C , 1 x USB 3.1 Gen 1 with Power Delivery - 24 pin USB-C , 2 x display / video - 20 pin DisplayPort , 1 x network - 1000Base-T - RJ-45 , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type A
1 x USB-C cable - external - 1 m
Dual monitor support, DisplayPort Alt Mode, 100W power delivery
FCC, RoHS, UASP (USB Attached SCSI Protocol)
Microsoft Windows 7 / 8 / 8.1 / 10
Limited warranty - 3 years
Shipping Weight
220 g
50 °C
DXYX StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £23.98
DXYX StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £15.80
DXYX StarTech.com DisplayPort to DVI Active Adapter In Stock £22.72
DXYX StarTech.com 10m Active DisplayPort Cable - DP to DP M/M In Stock £91.66
DXYX StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.67
DXYX StarTech.com Monitor Mount - USB Passthrough In Stock £176.82
DXYX StarTech.com Dual Monitor Mount - Stackable In Stock £226.92
DXYX StarTech.com Dual Monitor Stand In Stock £91.00
DXYX StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £23.58
DXYX StarTech.com Vertical Dual Monitor Stand In Stock £90.68
DXYX StarTech.com Vertical Dual Monitor Mount In Stock £76.91
DXYX StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £26.96
DXYX StarTech.com Dual 4K Docking Station, Mac & Windows - USB-A & USB-C Dock, Dual 4K60 DP & HDMI In Stock £134.82
DXYX StarTech.com Thin Client Mount - VESA In Stock £26.25
DXYX StarTech.com 1.8m USB 3.1 5Gbps with PD (5A) C to C Cable - M/M Certified In Stock £24.61
DXYX StarTech.com 20" USB C Cable 10Gbps Gen2 In Stock £13.40
DXYX StarTech.com 6ft USB C Cable 5Gbps Gen1 In Stock £19.03
DXYX StarTech.com USB C Dock DP 4K30Hz or VGA In Stock £115.87
