StarTech.com USB-C Multiport Adapter - HDMI/VGA
Quicklinx: H5LFWS00 Mfr#: DKT31CVHPD3
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Space grey
21 In Stock
£28.49 ex VAT
£34.18 inc VAT
Connect this USB Type-C Multiport Adapter to a USB-C, USB4, or Thunderbolt 3/4 laptop to enable single-display 4K 60Hz HDMI 2.0b or 1080p 60Hz VGA video output via DP Alt Mode. The USB-C dock works with USB Type-C laptops or tablets, such as a Chromebook, Dell XPS, or MacBook. It features a 3-Port USB 3.2 Gen 2 (10Gbps) Hub (2x USB-A, 1x USB-C), and Gigabit Ethernet. Connect the laptop USB-C power supply to the dedicated USB Power Delivery (PD) 3.0 port, to charge the laptop.
  • Extra-Long Cable with Built-in Cable Manager
    The Multiport Adapter features an extra-long attached 12.6in. (32cm) USB-C host cable. The Thermoplastic Elastomer (TPE) cable jacket is softer and more flexible than PVC jacketed cables. The extra-long cable reduces port/connector strain, particularly when laptops are placed on riser stands, or on 2-in-1 devices with raised USB-C ports, such as the Microsoft Surface. In addition, the Multiport Adapter also features an innovative wrap-around cable manager that facilitates tangle-free storage in a laptop bag.
  • USB 3.2 Gen 2 Hub
    Connect one USB-C and two USB-A peripherals to the USB 3.2 Gen 2 (10Gbps) ports.
  • Multiple Applications
    A versatile solution for adding docking station capabilities in an office, home office, hotel, or in the boardroom. It's portable enough to be carried in a bag or backpack. This lightweight USB-C Adapter can operate with bus-power alone or connect a USB-C power adapter (not included with Multiport Adapter) for laptop charging. USB PD 3.0 features Fast Role Swap (FRS) to prevent USB data disruption when disconnecting the power source.
  • Wired Gigabit Network Connectivity
    The Gigabit Ethernet port ensures reliable wired network access, with support for PXE Boot and Wake-on-LAN (WoL).
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that is compatible with a wide variety of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : Setup and save custom windows layouts. •Text | MAC Address Pass-Through Utility : Improve network security. •Text | USB Event Monitoring Utility : Track and log connected USB devices. •Text | Wi-Fi Auto Switch Utility : Enable quick access to wired LAN.
StarTech.com USB-C Multiport Adapter, HDMI/VGA, 4K 60Hz Video, 3-Port USB Hub, 100W Power Delivery Pass-Through, GbE, USB Type-C Travel Dock w/ Charging, 1ft/30cm Wrap-Around Cable - Mini Laptop Docking Station (DKT31CVHPD3) - docking station - USB-C - VGA, HDMI - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
VGA, HDMI
6.4 cm x 12.4 cm x 2.5 cm
130 g
Space grey
Gigabit Ethernet
Power adapter 16 Watt Power Provided
3-year warranty
Docking station
6.4 cm
12.4 cm
2.5 cm
130 g
Enclosure Colour
Space grey
Video
Max Resolution Details
4096 x 2160 - 60 Hz (HDMI only) , 1920 x 1200 - 60 Hz (VGA only) , 1920 x 1080 - 60 Hz (VGA only)
USB 3.2 Gen 2
1 x display / video - HDMI output - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 2 x USB-C 3.2 Gen 2 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C (power only) , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x USB-C 3.2 Gen 2 cable - integrated - 30 cm
Wake on LAN, Preboot Execution Environment (PXE) support, 2 LED indicators, full duplex support, DisplayPort Alt Mode, plastic housing, 100W power delivery (pass-through), up to 10Gbps data transfer, 84W charging
RoHS, WEEE, RCM, DisplayPort 1.4
Power adapter
Power Provided
16 Watt
Linux, Android, Google Chrome OS, Ubuntu 18.04, Apple macOS 10.15, Ubuntu 20.04, Apple macOS 12, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 13.0, Apple macOS 11
Limited warranty - 3 years
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
154 g
50 °C
H5LF StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £10.14
H5LF StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.03
H5LF StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.55
H5LF StarTech.com USB-C Multiport Adapter - HDMI/DP In Stock £43.16
Device Type: Laptop
Colour: Space grey
