A USB 3.1 Gen 2 Type-C hub adapter, ideal for travel, features everything from the essential HDMI or VGA video outputs to faster USB-C & USB-A peripheral ports.?All through a single host cable, providing more flexibility for harder to reach laptop and tablet connections.
Two Video Output Options with HDMI & VGA
This?USB-C multiport adapter?features both an 4K 30Hz HDMI and VGA port providing you with two?single?video output options for your?boardroom presentations or your?workstation setup including support for an ultra-wide monitor. -
Designed for Portability & Ease of Use
The USB-C travel dock is bus-powered through an attached extended length 29cm host cable, accommodating a wide variety of setups, so there's no need to carry around a separate bulky power adapter. Installation is fast and simple, with native support in most operating systems and at only 1.94 ounces (55 g) and taking up less space than your smartphone, this dock easily fits in your laptop bag or briefcase. -
Simplistic Port Configuration
In addition to the video outputs, the portable USB-C dock gives you one 10G USB-C port and USB-A port to connect your latest and legacy USB devices.?The adapter also integrates a Gigabit Ethernet port to access a wired network. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
- StarTech.com USB-C Multiport Adapter - USB 3.1 Gen 2 Type-C Mini Dock - USB-C to 4K HDMI or 1080p VGA Video - 10Gbps USB-A USB-C, GbE - Portable Travel Laptop Dock - Works w/Thunderbolt 3 (DKT31CHVL) - docking station - USB-C - VGA, HDMI - 1GbE - TAA Compliant
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- VGA, HDMI
- 6.1 cm x 6 cm x 1.7 cm
- 55 g
- Black
- Networking
- Gigabit Ethernet
- TAA Compliant
- 3-year warranty
- Product Type
- Docking station
- 6.1 cm
- 6 cm
- 1.7 cm
- 55 g
- Enclosure Colour
- Black
Video
- Max Resolution Details
- 3840 x 2160 - 30 Hz (HDMI only) , 2048 x 1280 - 30 Hz (VGA only)
- Data Link Protocol
- 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 1000Base-T - RJ-45 , 1 x USB-C / Thunderbolt 3 with Power Delivery - 24 pin USB-C
- Cables Included
- 1 x USB-C cable - integrated - 25 cm
- Bus powered, auto MDIX support
- FCC, RoHS, WEEE, REACH, RCM, UASP (USB Attached SCSI Protocol)
- TAA Compliant
- OS Required
- Android, Google Chrome OS, Apple macOS 10.12 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years , Technical support - lifetime
- 0 °C
- 60 °C
StarTech.com USB-C Multiport Adapter - 10Gbps Mini Dock 4K 60Hz HDMI/DisplayPort/1080p VGA | In Stock | £82.86 |
StarTech.com USB C Multiport Adapter - 4K HDMI/PD/USB/GbE- Mini Dock | In Stock | £56.64 |
StarTech.com USB C Multiport Adapter | In Stock | £71.24 |
StarTech.com 6ft Premium Certified HDMI 2.0 | In Stock | £16.02 |
