StarTech.com USB-C Dual-4K Monitor Docking Station for Laptops
Quicklinx: DNR2WS00 Mfr#: DK30CHDPPDUE
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black, Silver
Hurry, only 3 left in stock!
£130.05 ex VAT
£156.06 inc VAT
Add dual monitors (4K HDMI & 4K DP), an SD card reader, multiple USB ports, GbE, and audio to your laptop, plus power and charge your laptop. This dual-monitor USB-C dock transforms your MacBook or Windows laptop into a dual Ultra HD 4K workstation, with support for 4K DisplayPort and HDMI monitors. It gives you all the connections to create a fully capable workstation, including an SD card reader slot.
The USB-C docking station features USB Power Delivery 2.0 (60W), to power and charge your laptop as you work. It's the perfect companion for your MacBook Pro or other Thunderbolt 3 equipped laptop.
The USB-C dock expands the display capabilities of your laptop across two Ultra HD 4K monitors. It enables DisplayLink and USB-C DP Alt Mode to allow dual 4K video output to HDMI and DisplayPort 4K monitors. With the dual-4K dock, you can connect: 1x 4K DisplayPort display at 3840 x 2160 resolution @ 30Hz; 1x 4K HDMI display at 3840 x 2160 resolution @ 30Hz.
The dock provides direct access to your SD memory cards or microSD cards (with adapter). The SD card slot can also be used for additional storage and backup through macOS X Time Machine or Windows 10 File History.
The dock provides four USB 3.0 (Type-A) ports to connect your peripherals, including a USB 3.0 fast-charge and sync port, a Gigabit Ethernet port, and combined 3.5 mm audio and microphone port.
Compatible with Mac and Windows, this universal dock works with USB-C and Thunderbolt 3 enabled laptops.
StarTech.com USB C Dock, Dual Monitor HDMI & DisplayPort 4K 30Hz, USB Type-C Laptop Docking Station 60W Power Delivery (PD), SD, 4-port USB-A 3.0 Hub, GbE, Audio, Thunderbolt 3 Compatible - USB 3.1 Gen 1 Dock (DK30CHDPPDUE) - docking station - USB-C - HDMI, DP - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
HDMI, DP
8 cm x 22 cm x 2.5 cm
385 g
Black, silver
United Kingdom, Europe
Gigabit Ethernet
Power adapter AC 120/230 V 60 Watt Power Provided
3-year warranty
Docking station
8 cm
22 cm
2.5 cm
385 g
Enclosure Colour
Black, silver
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1
Expansion Slots
1 (total) / 1 (free) x SD / MMC Memory Card
1 x USB-C - input - 24 pin USB-C , 4 x SuperSpeed USB 3.0 - output - 9 pin USB Type A , 1 x display / video - HDMI output - 19 pin HDMI Type A , 1 x display / video - DisplayPort output - 20 pin DisplayPort , 1 x audio - output - mini-phone 3.5 mm 4-pole , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
Compatible Slots
1 x SD / MMC Memory Card
1 x USB-C cable - external
Dual monitor support, UASP transfer protocol, 1 USB 3.0 fast charging port, DisplayLink DL-5700 chipset, Genesys Logic GL3515 chipset, VLI VL813 chipset, Texas Instruments TPS65983 chipset
Power adapter
AC 120/230 V
Power Provided
60 Watt
Apple MacOS X 10.9 - 10.12, Google Chrome OS 55 or later, Ubuntu 18.04, Ubuntu 20.04, Apple macOS 11.0, Apple macOS 10.14 - 10.15, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
Shipping Weight
1.4 kg
60 °C
DNR2 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.98
DNR2 StarTech.com 3.5mm 3 Pin Headset Splitter In Stock £6.39
DNR2 StarTech.com 2m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £12.31
DNR2 StarTech.com 3m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £24.83
DNR2 StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £11.42
DNR2 StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.38
DNR2 StarTech.com 6 ft DP to HDMI cable - 4K In Stock £15.82
Device Type: Laptop
Colour: Black
Colour: Silver
