This USB to DisplayPort adapter lets you connect your computer to a 4K DisplayPort monitor using a USB 3.0 Type A port, even if your computer doesn’t support 4K video.
Increase your productivity by adding a 4K display
This USB to DP adapter can boost your productivity by providing more screen space to work with. Having multiple displays gives you the freedom to access two full-screen applications simultaneously, enabling you to reference material on one display while composing on another. The adapter even supports display rotation for a vertical screen that’s ideal for viewing spreadsheets, newsfeeds or stock tickers. -
Easy to install
The multi-monitor adapter is powered by your computer's USB Type A port, so you won’t need to connect a bulky external power adapter. Plus, the drivers install quickly and easily and only need to be installed once, regardless of how many USB video adapters you want to connect. -
Get astonishing picture quality with 4K video
Even if your system doesn’t natively support 4K video output, this USB video adapter lets you enjoy the picture quality of Ultra HD video. With support for 4K at 30 Hz, you get sharp and crisp picture quality, that’s richer and more true-to-life, with far greater detail in both darker and brighter images.
- StarTech.com USB 3.0 to DisplayPort Adapter - 4K 30Hz - External Video & Graphics Card - Dual Monitor Display Adapter - Supports Windows (USB32DPES2) - DisplayPort adapter - USB Type A to DisplayPort - TAA Compliant - 20 cm
- 4K30Hz (3840 x 2160) support, plastic housing, 64 MB memory
- Length
- 20 cm
- Connector
- 9 pin USB Type A - male (input)
- Connector (Second End)
- 20 pin DisplayPort - female (output)
- USB 3.0
- Black
- TAA Compliant
- 2-year warranty
- Length
- 20 cm
- Black
- 5.5 cm
- 7.5 cm
- 1.6 cm
- 58 g
- Connector
- USB 3.0, FCC, RoHS
- TAA Compliant
- Shipping Width
- 14.4 cm
- Shipping Depth
- 21 cm
- Shipping Height
- 3.8 cm
- Shipping Weight
- 190 g
- 2-year warranty
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £14.12 |
StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p | In Stock | £36.51 |
StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p | In Stock | £53.79 |
StarTech.com 1m 3.3ft DisplayPort 1.4 Cable | In Stock | £13.68 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £12.26 |
