Capture DVDs or VHS to your PC. The SVID2USB2 USB 2.0 S-video/composite video capture cable lets you connect devices that output S-video or composite video to a computer through an available USB 2.0 port. The cable also features two channel RCA stereo audio inputs that let you capture the audio accompanying the S-video or composite video signal.
The perfect solution for bridging a computer and an S-video or composite video source, the capture cable offers real time MPEG 1, MPEG 2 and MPEG 4 recording. Small enough to fit in the palm of your hand, the capture cable is a great solution for mobile applications that integrates seamlessly with laptop and desktop computers.
- StarTech.com S-Video & Composite to USB Video Capture Device Cable w/ Audio - video capture adapter - USB 2.0
- Video capture adapter
- Interface Type
- USB 2.0
- Black
- Video Input
- S-video input, composite video input
- Analogue Video Format
- NTSC, SECAM, PAL
- Analogue video Signal
- S-Video, composite video
- Digital Video Format
- MPEG-1, MPEG-2, MPEG-4
- Frame Rate
- NTSC: 30 frames per second
- Digital Video Capture Resolution
- 720 x 480, 720 x 576
- Audio Input Support
- Standard
- Sharpness control, brightness control, contrast control
- OS Required
- Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
- 2-year warranty
- Interface Type
- USB 2.0
- Black
Video
- Interface Type
- NTSC, SECAM, PAL
- Frame Rate
- Standard
- 1 x display / video - composite video input - RCA , 1 x display / video - S-video input - 4 pin mini-DIN , 1 x audio - line-In - RCA x 2
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Plug and Play, FCC, RoHS
- OS Required
- Limited warranty - 2 years , Technical support - lifetime
