Add a 14-in-1 high capacity external memory card reader to any USB computer. This USB 2.0 14-in-1 media memory card reader offers fast and convenient access to the most popular media/memory card formats including SD, Compact Flash, MMC, Memory Stick and IBM Micro Drive as well as SDHC cards for applications requiring high capacity storage.
Simply connect the card reader to a USB 2.0 port on the host computer, then insert the memory card into the reader for read/write access to the contents of the media/memory card. The card reader supports full hi-speed transfer rates of up to 480Mbps using a USB 2.0 connection and is backward compatible with USB 1.1, ensuring compatibility with virtually any USB capable computer.
- StarTech.com 14-in-1 USB 2.0 High Capacity Silver Multi Media Memory Card Reader - card reader - USB 2.0
- Product Type
- Card reader - external
- Supported Memory Cards
- CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, SmartMedia Card, Memory Stick Duo, Memory Stick PRO Duo, miniSD, RS-MMC, SDHC Memory Card
- Host Interface
- USB 2.0
- 2-year warranty
- Designed For
- P/N: USB1000IP
- Product Type
- Host Interface
- USB 2.0
Memory Card
- Capacity
- (max)
- Required Ports
- 1
- OS Required
- Apple MacOS X 10.1.2 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista
- Included Accessories
- USB cable
- Software Included
- Drivers & Utilities
- FCC, RoHS
- Limited warranty - 2 years
- Designed For
- P/N: USB1000IP
Customer reviews
Write a review for the StarTech.com USB 2.0 Multi Card Reader here!
a good one
Reviewed by Peng. Review Posted 09/07/2008
Compact and stylish, easy to use. Works fine with high capacity cards and the transfer rate is faster than my build-in card reader with the laptop. Very good value of money, recommonded!
Overall
Ease of use
Value for money
good but not perfect
Reviewed by John. Review Posted 18/04/2009
Pros:
1. Lots of card slots;
2. Very Cheap;
3. Very fast
4. Easy to use - just plug it in.
Only 3 minor probs:
1. The build quality whilst solid, feels cheap and the cards are not a snug fit, you may have to wiggle them a little to get them to fit.
2. Card eject instructions are wrong, they will eject the card reader; instead go to My Computer, right click on the drive and select eject.
3. My computer will not boot-up if the reader is plugged in (it doesn't even get the bios splash screen) - if you get this prob just unplug it and plug back in when Windows has loaded - easy.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
