StarTech.com Universal Dock USB-C & USB 3.0 60W PD
Quicklinx: F2K0WS00 Mfr#: DK30C2DPPDUE
Device Type: Macbook, Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black, Space grey
38 In Stock
£210.66 ex VAT
£252.79 inc VAT
Transform your laptop into a dual-4K 60Hz workstation with this universal laptop docking station, for USB-C and USB 3.0 laptops. Connect to dual DisplayPort or HDMI monitors. Attach USB devices with four USB 3.0 ports. Plus, power your USB-C laptop with 60W Power Delivery.
The USB-C and USB 3.0 docking station provides IT professionals with a convenient one-dock solution for offices using different laptop brands and operating systems. The dock works with Dell, HP, Lenovo, MacBook and most other laptops.
The dual-4K docking station connects your laptop to Ultra HD DisplayPort or HDMI monitors: 2x 4K DisplayPort up to 4096 x 2160p @ 60Hz; 2x 4K HDMI up to 4096 x 2160p @ 60Hz; 1x 4K DP + 1x 4K HDMI display @ 60Hz.
Connect to a single 5K display using two DP ports.
Using a single cable, the dock powers and charges your laptop as you work with 60W PD, using the 135W power adapter.
For fast setup right out of the box, the combo cable (USB-C with attached USB-A adapter) lets you connect any laptop. The dock has mounting holes for workstation mounting (bracket not included).
Connect your devices with four USB 3.0 ports: 1x USB-C and 3x USB-A. Fast-charge your USB-C or USB-A smartphone. The dock provides a GbE port (PXE Boot support) and 3.5 mm 4-position headset audio jack. It also includes a security lock slot (K-slot) to protect against theft.
StarTech.com USB-C & USB-A Dock, Hybrid Universal Laptop Docking Station with Dual Monitor Display 4K 60Hz HDMI & DisplayPort, 60W Power Delivery, Gigabit Ethernet, Windows, Mac Chrome - 4K USB Type-C Dock (DK30C2DPPDUE) - docking station - USB-C - 2 x HDMI, 2 x DP - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
2 x HDMI, 2 x DP
22 cm x 8 cm x 3 cm
280 g
Black, space grey
United Kingdom, Europe
Gigabit Ethernet
Power adapter AC 120/230 V
3-year warranty
Docking station
22 cm
8 cm
3 cm
280 g
Enclosure Colour
Black, space grey
Video
Max Resolution Details
4096 x 2160 - 60 Hz
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
1 x USB 3.1 Gen 1 with Power Delivery - 9 pin USB Type A , 2 x USB 3.1 Gen 1 with Power Delivery - 24 pin USB-C , 2 x display / video - 20 pin DisplayPort , 2 x display / video - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB 3.1 Gen 1 - 9 pin USB Type A , 1 x headphone/microphone combo jack - mini-phone 3.5 mm
1 x USB-C cable - external - 1 m
Security lock slot (cable lock sold separately), dual monitor support, Preboot Execution Environment (PXE) support, full duplex support, DisplayPort Alt Mode, 60W power delivery
Security Slot Type
Kensington security slot
FCC, RoHS, USB Battery Charging Specification Rev. 1.2, DisplayPort 1.2, UASP (USB Attached SCSI Protocol), USB Power Delivery 3.0
Power adapter
AC 120/230 V
Apple MacOS X 10.11 - 10.12, Google Chrome OS 55 or later, Ubuntu 18.04, Apple macOS 10.14, Apple macOS 10.15, Ubuntu 20.04, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
50 °C
F2K0 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.37
F2K0 StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £9.78
F2K0 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.86
F2K0 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.12
F2K0 StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 In Stock £25.84
F2K0 StarTech.com 10m Active DisplayPort Cable - DP to DP M/M In Stock £91.66
F2K0 StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £16.29
F2K0 StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £10.55
F2K0 StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.82
F2K0 StarTech.com Triple-Video Laptop Dock In Stock £100.82
F2K0 StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla In Stock £9.06
F2K0 StarTech.com Docking Station Mount - For StarTech.com Docks / Hubs - VESA In Stock £14.35
F2K0 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.26
Device Type: Laptop
Colour: Black
Colour: Space grey
