Get reliable and cost-efficient Gigabit Ethernet connections over multi-mode fiber with this Mini-GBIC module. This HP compatible Gigabit fiber SFP is engineered by StarTech.com to deliver what you need most in your network connections: reliability. Built to exacting specifications and fully tested to ensure maximum performance, you can install this high-quality fiber transceiver module into HP networking devices that support the J4858C transceiver module, as well as other major brands of networking equipment.
This 1000Base-SX SFP delivers Gigabit connectivity over multimode fiber cable, with a range of up to 550 m (1804 ft.). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment. For large-scale requirements and maximum cost-savings, this GbE fiber SFP is also available in a 10-pack: J4858C10PKST.
This Gigabit SFP optical transceiver is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
The multimode Gigabit SFP is engineered to the highest quality standards and is 100% HP compatible, equivalent to the HP J4858C mini-GBIC. The StarTech.com SFP transceiver is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a multitude of Gigabit networking devices.
Ideal for use in HP switches, routers and other networking equipment, the SFP provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The SFP supports multimode fiber cable with a maximum distance of 550 m or 1804 ft., and maximum data rates of up to 1.25Gbps. This GbE fiber SFP also supports Digital Diagnostics Monitoring (DDM).
- StarTech.com HPE J4858C Compatible SFP Module, 1000BASE-SX, 1GbE Multi Mode (MMF) Fiber Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 550m, 850nm, DDM, HPE 1400, 1700, 1820 - Lifetime Warranty (J4858CST) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-SX
- Data Transfer Rate
- 1.25 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 550 m
- OEM Manufacturer Equivalent Part Number
- HP J4858C
- 1.3 cm x 5.7 cm x 1.4 cm
- Limited lifetime warranty
- Designed For
- P/N: IES101G2SFPW, IES101GP2SFW
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-SX
- 1GbE
- 1.25 Gbps
- 850 nm
- 550 m
- Full duplex capability, half duplex mode, Digital Diagnostics Monitoring (DDM)
- IEEE 802.3z
- 1 x Ethernet 1000Base-SX - LC multi-mode x 2
- UL, FCC, RoHS, MSA
- HP J4858C
- 1.3 cm
- 5.7 cm
- 1.4 cm
- Limited warranty - lifetime
- 0 °C
- 70 °C
- 30 - 75%
- Designed For
StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £16.22 |
StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £27.07 |
StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £17.35 |
StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £21.31 |
StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £18.84 |
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC | In Stock | £160.38 |
StarTech.com Fiber Media Converter - Open | In Stock | £48.56 |
StarTech.com SFP - HP J4858C Comp. 10 Pack | In Stock | £247.21 |
StarTech.com SFP - HP J4859C Comp. 10 Pack | In Stock | £284.91 |
StarTech.com SFP - HP J4858C Compatible | In Stock | £37.48 |
StarTech.com Gb RJ45 SFP - HP Compatible | In Stock | £36.41 |
StarTech.com SFP+ - HP J9151A Compatible | In Stock | £168.21 |
StarTech.com SFP+ - HP JD092B Compatible | In Stock | £133.26 |
StarTech.com SFP - HP J4859C Compatible | In Stock | £44.53 |
StarTech.com Gb Copper SFP HP 453154-B21 Compatible | In Stock | £56.73 |
StarTech.com 10 Gb SFP+ HP 455883-B21 Compatible | In Stock | £254.64 |
StarTech.com HP JD089B Compatible SFP | In Stock | £39.71 |
StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports | In Stock | £368.50 |
