Your basket is empty
StarTech.com Serial ATA / SAS cable - 0.9 m
Quicklinx: 4KXJWS00 Mfr#: SATA36
Length: 0.9m
£2.99 ex VAT
£3.58 inc VAT
Connect and position SATA drives easily - designed for larger cases. The SATA36 Serial ATA Cable features two 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com SATA Serial ATA Cable - Serial ATA cable - 0.9 m
Serial ATA cable
Interface Speed
Serial ATA 150
Length
0.9 m
Connector(s)
1 x 7 pin Serial ATA - female
Connector(s) (Other Side)
Red
P/N: PEXSAT31E1, SATSASBAY425, PEXSAT32, BRACKET25SAT, SAT2510U2S, PEXSATA22I, PEXSAT2IDE2, SAT2510U2REM, PCISAT2IDE1, SATABAY5BK, SATABAY3BK, SATABAY4BK, PCISATA4R1
Storage Cable Type
Serial ATA cable
Interface Speed
Serial ATA 150
Length
0.9 m
Red
Connector(s)
StarTech.com 1x eSATA + 1x SATA 6Gbps PCI Express SATA Controller Card, 2 Port SATA 6 Gbps PCI Express SATA Controller Card, 2.5in Hard Drive to 3.5in Drive Bay Mounting Kit, 2.5in SATA External Hard Drive Enclosure for 3.5/5.25 Front Drive Bay, 2S1I PCI SATA IDE Combo Controller Adapter Card, 2S2I PCI Express SATA IDE Combo Controller Adapter Card, 3 Drive 3.5in SATA Hot Swap Hard Drive Backplane with RAID, 4 Drive 2.5in Removable SAS SATA Mobile Rack Backplane, 4 Drive 3.5in Hot Swap SATA Mobile Rack Backplane, 4 Port PCI SATA RAID Controller Adapter Card, Extra 2.5in SATA Hard Drive Enclosure for SAT2510U2REM
Length: 0.9m
Type: ATA
Stock Status: Clearance
Price Range Ex VAT: 0 - 50
