20 Pack End Piece White UL Approved. This 20-pack of raceway end pieces work with the StarTech.com CBMCWD5020 raceway system.
Cap Your Raceway off, to Create a Finished Look
Use these cable raceway end pieces with the StarTech.com CBMCWD5020 raceway to cap them off and create a finished look in your office or server room.
Industrial Strength
Made from sturdy self-extinguishing ABS that's also warp proof, these wiring duct connectors are UL approved with 94HB Flamability (Horizontal Burning) Rating.
Use in Combination with Other Raceway Accessories
Combine this end piece with other StarTech.com CBMCWD5020 raceway system accessories to give your cable management solution a finished look.
The Coupler (CBMCWD5020C) (20-Pack), joins two raceways together and extends the length of your raceway.
The Inside Elbow (CBMCWD5020I) (20-Pack), joins two raceways together inside of corners at 90 degree angle.
The Lateral Elbow (CBMCWD5020L) (20-Pack), joins two raceways together and runs them up the wall at a 90 degree angle.
The Outside Elbow (CBMCWD5020O) (20-Pack), joins two raceways together around corners at a 90 degree angle.
The T Connector (CBMCWD5020T) (20-Pack), joins three raceways together in T-bar.
This cable management raceway end piece is TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
Join two raceways together and run them up the wall at a 90 degree angle
Use these cable raceway lateral elbows with the CBMWWD5020 raceway to join two of them together at a 90 degree angle to extend the length of your raceway up walls in your office or server room. -
Industrial strength
Made from sturdy self-extinguishing ABS that's also warp proof, these wiring duct elbow connectors are UL approved with 94HB Flamability (Horizontal Burning) Rating.
- StarTech.com 20 Pack Cable Raceway End Cap for CBMCWD5020, Cable Management Accessories, Channel Raceway Fitting End Cap, Cable Raceway Connectors, Wiring Duct End Piece, UL Listed - ABS Plastic, UL94 HB (CBMCWD5020E) - cable raceway end cap - TAA Compliant
- Product Type
- Cable raceway end cap
- Packaged Quantity
- 20 (specifications are for single item)
- 5.39 cm x 1.591 cm x 2.177 cm
- 4 g
- Product Material
- Acrylonitrile butadiene styrene (ABS)
- White
- TAA Compliant
- 2-year warranty
- Designed For
- P/N: CBMCWD5020
- Packaged Quantity
- Product Type
- Product Material
- 5.39 cm
- 1.591 cm
- 2.177 cm
- 4 g
- Enclosure Colour
- White
- Self-extinguishing, UL rated
- TAA Compliant
- Shipping Width
- 22.5 cm
- Shipping Depth
- 19 cm
- Shipping Height
- 4 cm
- Shipping Weight
- 90 g
- Limited warranty - 2 years
- Designed For
- P/N: CBMCWD5020
