Install this set of five 1U vertical cable management hooks internally/externally along the posts of a standard 19" 2/4-post server rack, to organize power and network cables.
Enhance cable management
The cable D-ring organizer features a 0.4" (11 mm) opening to effortlessly insert bundled cables. Install multiple cable rings along the rack posts to improve airflow and minimize the port and connector strain. -
Optimized cable routing
Prevent sharp cable bends at connector ends and reduce port/connector stress by routing the cables through these hooks. -
Wide compatibility
This cable guide for racks and cabinets is constructed of steel and is compatible with any rack post that features 1U standard rack spacing. The powder-coated finish ensures durability, and the smooth surface prevents snagging and maintains cable integrity.
- StarTech.com 5-Pack 1U Vertical Cable Management D-Ring Hooks, Cable Manager For 19" Server Racks/Cabinets, Network Rack Wire Organizers, Cable Guide Rings - cable management ring (vertical) - 1U
- Product Type
- Cable management ring (vertical)
- Packaged Quantity
- 5 (specifications are for single item)
- Black
- Height (Rack Units)
- 1U
- Product Material
- Steel
- 4.5 cm x 10.1 cm x 4.5 cm
- 73 g
- Type D-ring
- 2-year warranty
- Packaged Quantity
- Product Type
- Product Material
- Steel
- 1U
- 4.5 cm
- 10.1 cm
- 4.5 cm
- 73 g
- Shipping Dimensions (WxDxH) / Weight
- 24 cm x 17 cm x 4.5 cm / 448 g
- Black
- Type D-ring
- EIA RS-310-D
- Limited warranty: - 2 years
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £22.74 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £17.25 |
StarTech.com M6 Rack Screws and Cage Nuts | In Stock | £17.25 |
