This PCI Express based 12V Powered USB Card allows you to add three Powered USB (USB PlusPower) ports to any standard form-factor sized computer, using an available PCI Express Slot.
Drawing power from either the PCI Express slot or the computer power supply, the powered USB adapter card provides up to 3A of current to each connected device, allowing for up to three Powered USB devices to be installed at the same time.
Plus, the PCI Express Powered USB Adapter card can be connected to the corresponding accessory daughter board PUSBADAP (2 Port Low Profile 12V/24V Powered USB Adapter Card), to create two additional Powered USB ports, but does not require a second PCI Express slot.
- StarTech.com 3 Port PCI Express 12V Powered USB Adapter Card USB Plus Power - USB adapter - PCIe - USB 2.0 x 3
- USB adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- Ports
- USB 2.0 x 3
- 12 cm x 6.9 cm
- 200 g
- Data Link Protocol
- USB, USB 2.0
- Data Transfer Rate
- 480 Mbps
- Processor
- 1 x NEC µPD720101GJ
- System Requirements
- Microsoft Windows 2003, Microsoft Windows 2000 / ME / XP/ Vista
- Limited lifetime warranty
- Designed For
- P/N: PUSBDYB24V06, PUSBDYB24V10, PUSBDYB24V03
- USB adapter
- Form Factor
- Plug-in card
- PCI Express x1
- Ports
- USB 2.0 x 3
- Connectivity Technology
- Wired
- USB, USB 2.0
- 480 Mbps
Processor / Memory
- Processor
- 3 x USB 2.0 - 8 pin USB PlusPower (12 V)
- Compatible Slots
- 1 x PCI Express x1
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 12 cm
- 6.9 cm
- 200 g
- Limited warranty - lifetime
- Designed For
- StarTech.com 24V to Hosiden+USB B Powered USB Cable
