The PEX1TO16R PCI Express x1 to x16 slot extension adapter allows for PCI Express (PCIe) cards up to x16 in size to be installed into x1 PCIe slots, within a 1U rack mount chassis - a necessary accessory for almost any 1U chassis enabling you to expand its capabilities by adding I/O ports or a dedicated graphics card.
- StarTech.com PCIe X1 to X16 Slot Extension Adapter for 1U Servers - PCIe x1 to PCIe x16 slot adapter - 1U
- Product Type
- Height (Rack Units)
- 1U
- 3.2 cm x 15.8 cm x 1.7 cm
- 25 g
- 2-year warranty
- Product Type
- 1U
- 3.2 cm
- 15.8 cm
- 1.7 cm
- 25 g
- Limited warranty: - 2 years , Technical support: - lifetime
- 0 °C
- 60 °C
